11-03-2016, 21:22 | #1 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1696369 Status: Offline Sonork: 91000 Thanks Meter: 8 | s7 edge G935F FRP.. need help |
11-03-2016, 21:29 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
6.0.1 SM-G935F G935FXXU1APB3 04/02/2016 6.0.1 SM-G935F G935FXXU1APAW 01/29/2016 https://samsung-firmware.org/model/SM-G935F/page/51 Also you can flash Sboot (BL) and Modem (CP) only to downgrade the firmware using Odin into download mode. Important: autoreboot uncheck the box in Odin. When finished, your phone will continue into download mode and Then you try again FRP With Chimera. CP_G935FXXU1APE9 https://www.androidfilehost.com/?fid=24533103863143010 BL_G935FXXU1APE9 https://www.androidfilehost.com/?fid=24533103863143009 If your phone has new firmware inside. Like G935FXXU1B and Z3X writes eng boot of G935FXXU1A. therefor, it stuck on logo. With full flash You can G935FXXU1A ... Factory reset phone and then a method of use Z3X. You have done Also With This method Universal Samsung FRP Bypass | RootJunky.com | |
The Following User Says Thank You to gcceleghg For This Useful Post: |
11-03-2016, 22:28 | #3 (permalink) | |
Member: 1696369 Status: Offline Sonork: 91000 Thanks Meter: 8 | tqvm.. my problem solve with u mathod sir Quote:
01-07-2017, 19:34 | #5 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2105654 Status: Offline Thanks Meter: 7 | G935F FRP 6.0.1 G935FXXU1BPK3 ANY FIX ? Selected model: SM-G935F Software version: 27.7 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM32 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.27.7 NOW PHONE STOCK ON SAMSUNG GALAXY S7 EDGE SCREEN ....! |
01-26-2017, 16:05 | #8 (permalink) |
Junior Member Join Date: Mar 2007
Member: 478122 Status: Offline Thanks Meter: 1 | https://www.youtube.com/watch?v=5t4retjolkE z3x 26.6 is ok |
The Following User Says Thank You to lukasz222 For This Useful Post: |
