05-30-2017, 10:16 | #31 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Romania Age: 37
Member: 607365 Status: Offline Sonork: 100.1590583 Thanks Meter: 294 | Quote:
The Following User Says Thank You to faurionutz For This Useful Post: |
05-30-2017, 10:38 | #33 (permalink) |
Member: 607365 Status: Offline Sonork: 100.1590583 Thanks Meter: 294 | I asked you firmware build number and you tell me android version... Put phone in recovery mode and there you will see build number. To be able to remove frp lock this way you are trying require a specific firmware version, not all are supported this way |
05-30-2017, 12:43 | #36 (permalink) | |
Crazy Poster Join Date: Oct 2015 Location: Hungary
Member: 2472240 Status: Offline Thanks Meter: 6 | Quote:
Ok, I flash the G935FXXU1APB6 firmware. I tried again, but in recovery mode in device manager "Samsung Android Phone" adb there is no port! Samsung drivers are installed Checking local file... Ok Searching server... not found Searching USB Flash interface... COM8 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... timeout Phone not found | |
05-30-2017, 13:01 | #37 (permalink) |
Member: 2472240 Status: Offline Thanks Meter: 6 | Ok, got it! Thanks! There is only one problem! No root. TWRP does not allow flash because oem unlock is not turned on Checking local file... Ok Searching server... not found Searching USB Flash interface... COM7 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... Ok Reading phone info... Model: Android version: Product code: Phone version: PDA version: CSC version: CSC country code: CSC sales code: HW version: Phone SN: Chip name: Modem board: RF cal date: IMEI: Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... false Root your phone manually and then repeat Done with Samsung Tool PRO v.28.1 Last edited by szunyi77; 05-30-2017 at 13:09. |
05-30-2017, 13:21 | #38 (permalink) | |
05-30-2017, 23:21 | #39 (permalink) |
No Life Poster Join Date: Feb 2002 Location: germany Age: 49
Member: 9584 Status: Offline Thanks Meter: 31 | how to unlock frp on nougat 7.0. i tried everything. downgrad is not possible. if i try to unlock it on download mode it stucks on samsung logo. i tried to flash combination file it doesnt even gone to download mode. i repaired the phone now but still frp lock on. please help z3x team thanks |
06-07-2017, 13:02 | #44 (permalink) | |
I have tried many firmware but did not let reset frp/react/ee AP_G935FXXU1APB6_CL7162483_QB8519839_REV00_user_lo w_ship.tar G935FXXU1APAW_BTU1APB2_UK_v6.0.1 etc thanks | |
06-07-2017, 13:06 | #45 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | You need to flash whole firmware not only ap i works Quote:
IF YOU.LIKE WHAT I POST PRESS❤ THANKS BUTTON | |
The Following User Says Thank You to souma_k For This Useful Post: |
