06-07-2017, 13:07 | #46 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 334773 Status: Offline Thanks Meter: 92 | 7.0 G935FXXU1DQE7 to 6.0.1 G935FXXU1APD1 after that use s7 frp tool for adb on and then can unlock frp in z3x to home screen. |
The Following User Says Thank You to scorpion_bashee For This Useful Post: |
08-07-2017, 16:37 | #49 (permalink) |
Major Poster Join Date: Apr 2017
Member: 2711575 Status: Offline Thanks Meter: 8 | I think Z3x is a star-box for samsung S1,2,3,4 and note 2 engineers! i actually feel so broken over my-so-called Pro activation coz ive practically never used it for any meaningful work other than unlocking old phones. |
08-07-2017, 17:26 | #50 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro if you are feeling so broken for activati g pro sell the box for people who are making money from this box what to say about other boxes that updates every 2 monther and add phones that costes les than 100$ brand new phone IF YOU.LIKE WHAT I POST PRESS THANKS BUTTON |
09-26-2017, 16:31 | #51 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2761757 Status: Offline Thanks Meter: 0 | hello , i need help? i knew on this i'm trying to enable adb on s7 edge .. but i dont have a file anybody can tell me which is this ,i download so many and all of them say fail |
09-26-2017, 19:30 | #55 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | You need to downgrade the phone to older firmware and then flash combination but why to complicat it use ufs frp new methode 10 sec you are done IF YOU LIKE WHAT I POST PRESS THANKS BUTTON |
The Following User Says Thank You to souma_k For This Useful Post: |
10-08-2017, 04:26 | #59 (permalink) |
Junior Member Join Date: Dec 2009 Location: Rajakhera, Dholpur, Rajasthan
Member: 1176693 Status: Offline Thanks Meter: 10 | samsung g935f/935fd frp reset without adb on we need 1. z3x box 2. uart cable 3. latest z3x tool installed process:- open tool connect uart cable to box switch off your phone connect with uart cable click on reset frp ufs hold vol. down and press power key for 3 sec tool detect handset now leave power key do not release vol. down tool auto reset frp done enjoy........ |
The Following 5 Users Say Thank You to coolrajmobile For This Useful Post: |
11-20-2017, 07:52 | #60 (permalink) |
Freak Poster Join Date: Jun 2016
Member: 2584900 Status: Offline Thanks Meter: 32 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' to deactivate Google account activation lock. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Reset FRP/React/EE Selected model: SM-G935F Selected port: COM4 USB Serial Port Software version: 29.9 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM73 detected Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 6.0.1 Product code: SM-G935FZKABTU Phone version: G935FXXU1APB2 PDA version: G935FXXU1APAW CSC version: G935FBTU1APB2 CSC country code: UK & IRE CSC sales code: BTU HW version: MP 0.801 Phone SN: RF8H403YWBV Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2016-02-01 RF cal date: 20160401 IMEI: 358809078791391 Checking Super user right... true Erasing FRP... OK Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Restoring kernel... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.9 |
