Old 06-07-2017, 13:07   #46 (permalink)
scorpion_bashee's Avatar
Member: 334773
Thanks Meter: 90
make sure same csc like ins , mid you can downgrade from
7.0 G935FXXU1DQE7 to 6.0.1 G935FXXU1APD1 after that use s7 frp tool for
adb on and then can unlock frp in z3x to home screen.
The Following User Says Thank You to scorpion_bashee For This Useful Post:
Old 06-07-2017, 13:17   #47 (permalink)
Member: 2472240
Thanks Meter: 6
Originally Posted by souma_k View Post
You need to flash whole firmware not only ap i works
IF YOU.LIKE WHAT I POST PRESS❤ THANKS BUTTON
I know all 4 flash files. That's what I did
Old 06-20-2017, 13:41   #48 (permalink)
Member: 16142
Thanks Meter: 21
HI
for me problem with
Checking local file... not found
Searching server... not found
Done with Samsung Tool PRO v.28.1
any solution please
Old 08-07-2017, 16:37   #49 (permalink)
Member: 2711575
Thanks Meter: 8
I think Z3x is a star-box for samsung S1,2,3,4 and note 2 engineers!
i actually feel so broken over my-so-called Pro activation coz ive practically never used it for any meaningful work other than unlocking old phones.
Old 08-07-2017, 17:26   #50 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,184
Bro if you are feeling so broken for activati g pro sell the box for people who are making money from this box what to say about other boxes that updates every 2 monther and add phones that costes les than 100$ brand new phone
IF YOU.LIKE WHAT I POST PRESS THANKS BUTTON
Old 09-26-2017, 16:31   #51 (permalink)
Member: 2761757
hello , i need help? i knew on this i'm trying to enable adb on s7 edge .. but i dont have a file anybody can tell me which is this ,i download so many and all of them say fail
Old 09-26-2017, 16:53   #52 (permalink)
Member: 2761757
no body can help me?
Old 09-26-2017, 18:03   #53 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,184
Do you have uart cable c3300k ? Cable rj45
Old 09-26-2017, 19:20   #54 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
My phone also stuck on logo.
i also need solution.
I have this uart c3300k cable
I also hear that boot file from combination pack can get it to adb
I need boot file for g935fd
Old 09-26-2017, 19:30   #55 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,184
You need to downgrade the phone to older firmware and then flash combination but why to complicat it use ufs frp new methode 10 sec you are done
IF YOU LIKE WHAT I POST PRESS THANKS BUTTON
The Following User Says Thank You to souma_k For This Useful Post:
Old 09-26-2017, 19:59   #56 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
Where is ufs frp new methode ?
i dont have ufs box
Old 09-26-2017, 20:06   #57 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,184
Z3x samsung pro tools latest
i dont have ufs box
Old 09-26-2017, 20:11   #58 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
i am using latest version z3x
Old 10-08-2017, 04:26   #59 (permalink)
Member: 1176693
Thanks Meter: 9
samsung g935f/935fd frp reset without adb on
we need
1. z3x box
2. uart cable
3. latest z3x tool installed
process:-
open tool
connect uart cable to box
switch off your phone
connect with uart cable
click on reset frp ufs
hold vol. down and press power key for 3 sec
tool detect handset
now leave power key
do not release vol. down
tool auto reset frp
done enjoy........
The Following 5 Users Say Thank You to coolrajmobile For This Useful Post:
Old 11-20-2017, 06:52   #60 (permalink)
Member: 2584900
Thanks Meter: 15
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To read security codes via diagnostic port:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't use this function.
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes DIAG' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' to deactivate Google account activation lock.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
To reset Google account activation lock with UART cable:
1. Phone must be powered off
2. Connect the phone to UART cable.
3. Select correct COM port in port settings.
4. Press 'Reset FRP UFS' and follow the instructions in program.
Operation: Reset FRP/React/EE
Selected model: SM-G935F
Selected port: COM4 USB Serial Port
Software version: 29.9
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM73 detected
Setup connection... OK
Reading data from phone... OK
Sending data to phone... OK
Waiting ADB device... OK
Reading phone info...
Model: SM-G935F
Android version: 6.0.1
Product code: SM-G935FZKABTU
Phone version: G935FXXU1APB2
PDA version: G935FXXU1APAW
CSC version: G935FBTU1APB2
CSC country code: UK & IRE
CSC sales code: BTU
HW version: MP 0.801
Phone SN: RF8H403YWBV
Chip name: EXYNOS8890
Modem board: SHANNON335
Security patch: 2016-02-01
RF cal date: 20160401
IMEI: 358809078791391
Checking Super user right... true
Erasing FRP... OK
Restoring kernel... OK
Rebooting phone... OK
Reset FRP done
Done with Samsung Tool PRO v.29.9
Page generated in 0.39747 seconds with 7 queries
