03-25-2017, 16:02 | #1 (permalink) |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 101 | S7 edge (G935F) Reset FRP Operation: Reset FRP/React/EE Selected model: SM-G935F Software version: 27.9 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM28 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.27.9 All other functions work fine, but only reset frp/react/ee doesn't work.. phone not found.. any solution please?? |
03-25-2017, 16:06 | #2 (permalink) | |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | Quote:
You need to enable ADB for it to work | |
03-25-2017, 16:10 | #3 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | You may have to flash the ENG Sboot file to enable ADB before removing the FRP lock. Look at this thread: http://forum.gsmhosting.com/vbb/f922...wares-2201348/ But in case that you want to have a little of fun, you can use this NO Smart Box/ Risk FREE method: http://forum.gsmhosting.com/vbb/f453...moval-2180813/ PLEASE CLICK ON THE THANKS BUTTON IF THIS POST WAS HELPFUL |
03-25-2017, 16:23 | #4 (permalink) |
Member: 2406539 Status: Offline Thanks Meter: 101 | usb debugging is enabled, but the problem is phone isn't found when it is connected for reset frp/react/ee, but when z3x gives error and done with Samsung Tool PRO v.27.9 computer shows that phone is connected in adb mode, i can perform normal frp function, but i'm trying to repair imei, so i want to reset frp/react/ee, so it will write kernel and will able to write imei and patch cert.. |
03-25-2017, 16:28 | #5 (permalink) | |
"Waiting ADB device... timeout Phone not found" | |
