S7 G930F 7.0 Unlock done S7 G930F 7.0 Unlock done Code: UNLOCK INSTRUCTIONS: https://s3.postimg.org/71yrwsi4j/TIGER.gif |
plz share the root file here |
root file is the problem. pls share |
Put your phone into download mode and run Odin Untick auto-reboot... Flash TWRP Recovery: https://dl.twrp.me/herolte/ After flashing TWRP, boot into recovery.. From wipe select Format Data... type yes and after wipe go back to Main Menu and select reboot, reboot to recovery.. After reboot browse to install and flash Supersu 2.82 (you can use SD-Card or OTG cable or ADB Push Command): SuperSU-v2.82-201705271822.zip Reboot your device... this will take up to 5 minutes PS: Wipe data is a MUST because when you swipe TWRP it will trigger dm-verity, and if you don't wipe you will be unable to boot |
I tried with root and without root , read code and direct unlock but no succes g930f v7.0 new security work only with downgrade modem |
