Old 07-24-2017, 06:04   #1 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 2,256
S7 G930F 7.0 Unlock done
  UNLOCK INSTRUCTIONS:
    To unlock NEW security type:
    Phone must be rooted!
  If the software can't root the phone automatically,
  then you must root your device manually.
  1. Power on the phone.
  2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
     go to 'Settings'-'Developer options' and enable 'USB debugging'.
  3. Connect the phone to PC with USB cable, install drivers if needed.
  4. Select device in ADB settings.
  5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
    To unlock OLD security type:
  2. Connect the phone to PC with USB cable.
  3. Check Samsung modem in device manager, install drivers if needed.
  4. Press 'Unlock' button and select 'Unlock' for direct unlock.
    To read security codes (all security types):
  4. Press 'Read codes' button to read security codes.
    To reset Google account activation lock:
  1. ADB must be activated in any way (you can flash sBoot from combination firmware,
     make sure, that you are not upgrade sBoot).
  2. Connect the phone to PC with USB cable, install drivers if needed.
  3. Select device in ADB settings.
  4. Press 'Reset FRP' to deactivate Google account activation lock.
   To reset Google account activation or Samsung reactivation lock:
  1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
  3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
    (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-G930F
Selected port: COM158 SAMSUNG Mobile USB Serial Port
Software version: 28.8
Waiting ADB device... OK
Reading phone info...
Model: SM-G930F
Android version: 7.0
Product code: SM-G930FZDAVOD
Phone version: G930FXXU1DQB1
PDA version: G930FXXU1DQBT
CSC version: G930FVFG1DQBT
CSC country code: UK
CSC sales code: VOD
HW version: MP 0.700
Phone SN: R58H63A4D1V
Chip name: EXYNOS8890
Modem board: SHANNON335
Security patch: 2017-02-01
RF cal date: 20160623
IMEI:
Checking Super user right... true
Reading NV data... OK
Checking NV data... OK
Reading data... OK
Detecting MODEM... OK
Reading MODEM... OK
Calculating... OK
Writing zTool... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data... OK
HWID:  06 D8 35 83 82 1A 0B A0 B7 62 85 70 8E 4C D7 B7
Calculating... OK
Unlocking... OK
Writing NV data... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.28.8
The Following 10 Users Say Thank You to haji rahim For This Useful Post:
Old 11-02-2017, 09:38   #2 (permalink)
Member: 599037
Thanks Meter: 97
plz share the root file here
Old 12-24-2017, 15:51   #3 (permalink)
Member: 320120
Thanks Meter: 73
root file is the problem. pls share
Old 12-24-2017, 16:06   #4 (permalink)
voltran2008's Avatar
Member: 861795
Thanks Meter: 576
WARNING: This will wipe your device, backup your data
Put your phone into download mode and run Odin Untick auto-reboot... Flash TWRP Recovery:
https://dl.twrp.me/herolte/
After flashing TWRP, boot into recovery.. From wipe select Format Data... type yes and after wipe go back to Main Menu and select reboot, reboot to recovery..
After reboot browse to install and flash Supersu 2.82 (you can use SD-Card or OTG cable or ADB Push Command):
SuperSU-v2.82-201705271822.zip
Reboot your device... this will take up to 5 minutes
PS: Wipe data is a MUST because when you swipe TWRP it will trigger dm-verity, and if you don't wipe you will be unable to boot
The Following 3 Users Say Thank You to voltran2008 For This Useful Post:
Old 12-24-2017, 16:11   #5 (permalink)
Member: 696136
Thanks Meter: 202
https://download.chainfire.eu/929/CF...xx-smg930f.zip
Always trust cfroot
Old 12-24-2017, 16:14   #6 (permalink)
Member: 861795
Thanks Meter: 576
Originally Posted by mobile mart View Post
Wrong... CF-Auto Root doesnt work on latest builds and author ChainFire ended CF-Auto Root Project....
Old 12-24-2017, 16:29   #7 (permalink)
Member: 696136
Thanks Meter: 202
Ended but still works for all present files on web page.
Old 02-15-2018, 12:21   #8 (permalink)
Member: 18823
Thanks Meter: 4
I tried with root and without root , read code and direct unlock but no succes
g930f v7.0 new security
work only with downgrade modem
Page generated in 0.13947 seconds with 7 queries
