10-08-2019, 21:31 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Devon, England
Member: 55766 Status: Offline Thanks Meter: 333 | S7 Reset FRP/React/EE error time out Help would be appreciated as been a long time since Ive done any of these. Operation: Reset FRP/React/EE Selected model: SM-G930F Software version: 37.0 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash interface... COM3 detected Setup connection... OK Reading data from phone... OK Sending data to phone... error timeout Done with Samsung Tool PRO v.37.0 Last edited by FU_Too; 10-08-2019 at 21:36. |
10-09-2019, 06:45 | #2 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
Sent from my SM-N950F using Tapatalk | |
10-24-2019, 22:32 | #3 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | Thanks for advice but unable to turn on ADB on phone because FRP tripped. Can you recommend a flash that I can use to activate ADB on phone? At moment in recovery it shows samsung/heroltexx/herolite 8.0.0/R16NW/G930FXXU5ESD2. Any help apreciated as its been a long yime since Ive worked on phones. |
10-25-2019, 00:34 | #4 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
COMBINATION_FA60_G930FXXU5ASD2.zip Download https://androidfilehost.com/?fid=1395089523397966598 G930FXXU5ESD2_G930FODD5ESE1_INS_8.0_Full.rar Download https://androidfilehost.com/?fid=6006931924117904363 | |
The Following User Says Thank You to amleto90 For This Useful Post: |
10-25-2019, 18:02 | #5 (permalink) | |
Member: 55766 Status: Offline Thanks Meter: 333 | Quote:
FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G930F Software version: 38.2 File analysis... OK Total file size: 0x100A40398 (4106 Mb) Searching USB Flash interface... COM6 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin.lz4... OK Sending param.bin.lz4... OK Sending cm.bin.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending system.img.lz4... OK Sending modem.bin.lz4... OK Sending modem_debug.bin.lz4... OK Sending cache.img.lz4... OK Sending hidden.img.lz4... error timeout Done with Samsung Tool PRO v.38.2 | |
10-25-2019, 18:09 | #6 (permalink) | |
10-25-2019, 20:10 | #9 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | I did the first part with the bin file, then went through the process of the FRP UFS reset which it said to go to backup/factory reset to complete the FRP removal So I assumed FRP was reset. now after had error with stock flash I tried using CSC_OXA_G930FOXA5ESD2_CL15877854_QB23332289_REV00_ user_low_ship.tar and flash completed ok BUT FRPis still locked. |
10-25-2019, 20:18 | #10 (permalink) | |
Or you can use 4 methods without combination file and box and pc In the videos you will find instructions on how to proceed SM-G930F Samsung Galaxy S7 FRP Bypass _ Android 8.0.0 https://www.youtube.com/watch?v=yz7aEYRfiXc smartwicth method https://www.youtube.com/watch?v=_J7To_t3yMk Or use this new method sim no active https://www.youtube.com/watch?v=rQZ651UkLow Or new method sim Pin security patch july 2019 https://m.youtube.com/watch?v=mQQtXYkLtPo | |
10-25-2019, 20:27 | #11 (permalink) | |
The Following User Says Thank You to souma_k For This Useful Post: |
10-28-2019, 17:56 | #14 (permalink) |
Member: 2613252 Status: Offline Thanks Meter: 1,837 | if you can't use the ufs method via uart via the z3x 38.2 version install an old version of z3x pro tool and try again if you see the same error, with the combination installed to reset frp, if you still have problems with the firmware flash in 4 files with the hidden img file, use the 4 methods I posted to you without combination and box to reset frp |
