06-27-2016, 05:06 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Canada
Member: 1211915 Status: Offline Sonork: 345634564 Thanks Meter: 93 | s7 UNLOCK FAILED PB7 MODEM 25.8 IMEI 0000 READ CODE NOT WORKING Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. (Note, that the cert file for this model is unique. You can write cert, wich is readed from this device exactly.) 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write NV DATA Selected model: SM-G930W8 Software version: 25.8 Waiting ADB device... OK Reading phone info... Model: SM-G930W8 Android version: 6.0.1 Product code: Phone version: G930W8VLU1APB7 PDA version: G930W8VLU1APB7 CSC version: G930W8OYA1APB7 CSC country code: Canada CSC sales code: FMC HW version: Phone S/N: Modem board: SHANNON335 RF cal date: IMEI: Checking Super user right... true Writing nv data... OK Recalculating md5... OK Deleting backup... OK Rebooting phone... OK Write NV Data done Done with Samsung Tool PRO v.25.8 ----------- 1. I tried reading codes and CODES NOT WORKING 2. I TRIED DIRECT UNLOCK AND AFTER DIRECT UNLOCK PHONE IS UNLOCK BUT IMei IS 00000000000000000000000000 3 I have tried pb7 modeM flash and then UNLOCK BUT STILL IMei 000000000000000000000 HOW TO UNLOCK ANY SOLUTION? I TRIED EVERYTHING BUT NO LUCK |
06-28-2016, 04:34 | #5 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
http://forum.gsmhosting.com/vbb/f453...935w8-2067903/ | |
