s7390 how to unlock unlock or read codes not working Selected model: S7390 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-S7390 Android version: 4.1.2 Product code: Unknown Phone version: S7390XXUAMI1 PDA version: S7390XXUAMI1 CSC version: S7390OXAAMI1 IMEI: 358599050****** Phone S/N: R21D974FKEL Checking Super user right... false Not supported version for auto root Done with Samsung Tool v.16.0 how to root ? you said full support ! http://forum.gsmhosting.com/vbb/f453...world-1725983/ |
Hy, Root phone using this: https://cydia.saurik.com/api/latest/2 Select "# drop SuperSU su to /system/xbin/su" After finish just unlock phone with z3x ;) |
After root: Selected model: S7390 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.16.0 Selected model: S7390 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM112 Reading phone info... Model: GT-S7390 Country code: ROM Cal date: - Factory SW: S7390XXUAMI1 Unique number: CN5087ADB726380 Memory phone: - Software version: IMEI: Product code: Done with Samsung Tool v.16.0 Selected model: S7390 Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-S7390 Android version: 4.1.2 Product code: Unknown Phone version: S7390XXUAMI1 PDA version: S7390XXUAMI1 CSC version: S7390OXAAMI1 IMEI: 358599050116853 Phone S/N: R21D93KWNBH Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.16.0 |
Selected model: S7390 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-S7390 Android version: 4.1.2 Product code: Unknown Phone version: S7390XXUAMI2 PDA version: S7390XXUAMI2 CSC version: S7390OXXAMI2 IMEI: 3585990501xxxxx Phone S/N: R21D93KWZNH Checking Super user right... true Reading data from phone... OK Please wait, calculating codes... OK (time - 00:01:06) NET lock: 00000000 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 Multi lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.16.1 Done with Samsung Tool v.16.1 THX BRO :-D |
Selected model: S7390 Selected port: COM12 Z3X BOX Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM69 Reading phone info... Model: GT-S7390 Country code: ROM Cal date: - Factory SW: S7390XXUAMI1 Unique number: CN508E9B98AB190 Memory phone: - Software version: IMEI: Product code: Done with Samsung Tool v.16.1 Selected model: S7390 Selected port: COM12 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-S7390 Android version: 4.1.2 Product code: Unknown Phone version: S7390XXUAMI1 PDA version: S7390XXUAMI1 CSC version: S7390OXAAMI1 IMEI: 358599050176311 Phone S/N: R21D974EYWM Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.16.1 Done with Samsung Tool v.16.1 B.R. |
Selected model: S7390 Selected port: COM205 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM204 Reading phone info... Model: GT-S7390 Country code: MTL Cal date: - Factory SW: S7390XXUAMI3 Unique number: CN508F8BB747590 Memory phone: - Software version: IMEI: Product code: Done with Samsung Tool v.16.1 Selected model: S7390 Selected port: COM205 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.16.1 Selected model: S7390 Selected port: COM205 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.16.1 i did use impactor but it still gives me "phone not found" after i select direct unlock or read codes... do you know were is the problem? |
error : signature bugs unavailable how to root with impactor ? step by step please android 4.1.2 |
finally done ! here are the steps if impactor cannot root yous s7390 put phone in download mode volume down + home + power write this firmware (ONE FILE) with odin S7390XWUAMI1_S7390OXEAMI3_S7390XWUAMI1_HOME.tar.md 5 wait for phone to power on enable debug mode now with impactor in white space bar must enter this drop SuperSU su to /system/xbin/su press start wait for program to finish now with z3x unlock Selected model: S7390 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-S7390 Android version: 4.1.2 Product code: Unknown Phone version: S7390XWUAMI1 PDA version: S7390XWUAMI1 CSC version: S7390OXEAMI3 IMEI: 3585990508******** Phone S/N: R21DA1KRPSJ Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.16.1 DONE BIG THANKS TO ALL ! |
good job work's for me |
restart your system mate;) |
Hi. Here is how I did my first one. First of all try to root it with this app from here https://cydia.saurik.com/api/latest/2 it's very simple just click Start while "# drop SuperSU su to /system/xbin/su" is selected. If it fails downgrade it to S7390XXUAMI2_OXXAMI2 (firmware is on support) and try rooting it again; it should work just fine. To downgrade it use Odin 3.07 and load PDA PHONE and CSC. It works without .PIT and with Re-Partition UNCHECKED. Only Auto Reboot and F. Time Reset should be checked. It will restart with German language set(change the language if you want), pass the wizard, enable Usb Debugging and exit to wallpaper. Now try to unlock it. If you get: Selected model: S7390 Selected port: COMxx SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Phone not found Type *#0808# and select "DM + MODEM + ADB" but don't close the window even if you clicked ok as it turns out it will not save it (at least it did so to me) just leave it on screen. Try again to read codes and if you get: Checking Super user right... true Reading data from phone... OK Please wait, calculating codes... OK (time - 00:00:40) Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 Multi lock: 00000000 For check lock status: *#7465625# use direct unlock because as you can see NCK is not displayed. If it's shown then obviously use it. Good luck everybody. |
can't unlcoker s7390 hi I can't unlocker s7390 with Samsung tool 16.7. I can read but when i click unlock he said me how to unlock samsung S7390 version 4.1.2? how to manual root? Selected model: S7390 Selected port: COM22 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-S7390 Android version: 4.1.2 Product code: Unknown Phone version: S7390XXUAMI1 PDA version: S7390XXUAMI1 CSC version: S7390OXAAMI1 IMEI: 358xxxxxxxxxxx Phone S/N: R21D93KYFAN Checking Super user right... false Not supported version for auto root Done with Samsung Tool v.16.7 who can help me |
Use this for root: http://cdnpic.mgyun.com/files/produc...4388_Setup.exe Selected model: S7390 Selected port: COM13 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-S7390 Android version: 4.1.2 Product code: Unknown Phone version: S7390XXUAMJ5 PDA version: S7390XXUAMJ3 CSC version: S7390ORLAMJ1 IMEI: 358599052985412 Phone S/N: R21DABA9FJD Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool v.16.8 |
Sir when i try to root my s7390 by this Impactor its showing (Signature Bugs Unabailable ) whats my falt plz guyd me .Thanks . |
If it fails downgrade it to S7390XXUAMI2_OXXAMI2 (firmware is on support) and try rooting it again; it should work just fine. |
