Old 10-14-2013, 10:42   #1 (permalink)
zullu2004's Avatar
Member: 146635
Sonork: 100.1651273
Thanks Meter: 258
s7390 how to unlock
unlock or read codes not working
Selected model: S7390
Selected port: COM3 Z3X BOX Serial Port
Selected port speed: 115200
Reading phone info...
Model: GT-S7390
Android version: 4.1.2
Product code: Unknown
Phone version: S7390XXUAMI1
PDA version: S7390XXUAMI1
CSC version: S7390OXAAMI1
IMEI: 358599050******
Phone S/N: R21D974FKEL
Checking Super user right... false
Not supported version for auto root
Done with Samsung Tool v.16.0
how to root ?
you said full support !
Z3X-BOX Samsung Update 16.0 - L720, T599, S6790 and other first in the world
Old 11-04-2013, 11:00   #2 (permalink)
golumbu's Avatar
Member: 39503
Thanks Meter: 42
Hy,
Root phone using this: https://cydia.saurik.com/api/latest/2
Select "# drop SuperSU su to /system/xbin/su"
After finish just unlock phone with z3x
The Following 8 Users Say Thank You to golumbu For This Useful Post:
Old 11-06-2013, 11:56   #3 (permalink)
stargsm_ro's Avatar
Member: 44085
Thanks Meter: 118
After root:
Selected port: COM7 Z3X BOX Serial Port
Phone not found
Searching Samsung modem... detected COM112
Model: GT-S7390
Country code: ROM
Cal date: -
Factory SW: S7390XXUAMI1
Unique number: CN5087ADB726380
Memory phone: -
Software version:
IMEI:
Product code:
Model: GT-S7390
IMEI: 358599050116853
Phone S/N: R21D93KWNBH
Checking Super user right... true
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Old 11-14-2013, 13:16   #4 (permalink)
Registered User
Member: 245884
Thanks Meter: 21
Selected port: COM8 Z3X BOX Serial Port
Model: GT-S7390
Phone version: S7390XXUAMI2
PDA version: S7390XXUAMI2
CSC version: S7390OXXAMI2
IMEI: 3585990501xxxxx
Phone S/N: R21D93KWZNH
Please wait, calculating codes... OK (time - 00:01:06)
NET lock: 00000000
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
Multi lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool v.16.1
THX BRO :-D
Old 11-18-2013, 14:41   #5 (permalink)
digitalgsm_cora's Avatar
Member: 727888
Thanks Meter: 216
Selected port: COM12 Z3X BOX Serial Port
Searching Samsung modem... detected COM69
Model: GT-S7390
Country code: ROM
Cal date: -
Unique number: CN508E9B98AB190
Memory phone: -
Software version:
IMEI:
Product code:
Model: GT-S7390
IMEI: 358599050176311
Phone S/N: R21D974EYWM
Unlocking... OK
Unlock done
B.R.
Old 11-19-2013, 15:34   #6 (permalink)
Member: 1226010
Selected port: COM205 SAMSUNG Mobile USB Serial Port
Searching Samsung modem... detected COM204
Model: GT-S7390
Country code: MTL
Cal date: -
Factory SW: S7390XXUAMI3
Unique number: CN508F8BB747590
Memory phone: -
Software version:
IMEI:
Product code:
Phone not found
Phone not found
i did use impactor but it still gives me "phone not found" after i select direct unlock or read codes... do you know were is the problem?
The Following User Says Thank You to paradisebg For This Useful Post:
Old 11-22-2013, 09:41   #7 (permalink)
zullu2004's Avatar
Member: 146635
Sonork: 100.1651273
Thanks Meter: 258
error : signature bugs unavailable
how to root with impactor ?
step by step please
android 4.1.2
The Following User Says Thank You to zullu2004 For This Useful Post:
Old 11-22-2013, 11:00   #8 (permalink)
zullu2004's Avatar
Member: 146635
Sonork: 100.1651273
Thanks Meter: 258
finally done !
here are the steps if impactor cannot root yous s7390
put phone in download mode
volume down + home + power
write this firmware (ONE FILE) with odin
S7390XWUAMI1_S7390OXEAMI3_S7390XWUAMI1_HOME.tar.md 5
wait for phone to power on
enable debug mode
now with impactor
in white space bar must enter this
press start
wait for program to finish
now with z3x unlock
Model: GT-S7390
Phone version: S7390XWUAMI1
PDA version: S7390XWUAMI1
CSC version: S7390OXEAMI3
IMEI: 3585990508********
Phone S/N: R21DA1KRPSJ
Unlocking... OK
Unlock done
DONE
BIG THANKS TO ALL !
The Following 2 Users Say Thank You to zullu2004 For This Useful Post:
Old 12-02-2013, 14:18   #9 (permalink)
Crazy Poster
Member: 1501026
Sonork: 100.1660399
Thanks Meter: 2
good job work's for me
Old 12-05-2013, 09:17   #10 (permalink)
Member: 665242
Thanks Meter: 15
Model: GT-S7390
Country code: MTL
Cal date: -
Memory phone: -
Software version:
IMEI:
Product code:
Phone not found
Phone not found
restart your system mate
Old 12-06-2013, 15:35   #11 (permalink)
Member: 626209
Thanks Meter: 41
Hi. Here is how I did my first one.
First of all try to root it with this app from here https://cydia.saurik.com/api/latest/2 it's very simple just click Start while "# drop SuperSU su to /system/xbin/su" is selected.
If it fails downgrade it to S7390XXUAMI2_OXXAMI2 (firmware is on support) and try rooting it again; it should work just fine.
To downgrade it use Odin 3.07 and load PDA PHONE and CSC. It works without .PIT and with Re-Partition UNCHECKED. Only Auto Reboot and F. Time Reset should be checked.
It will restart with German language set(change the language if you want), pass the wizard, enable Usb Debugging and exit to wallpaper. Now try to unlock it. If you get:
Selected port: COMxx SAMSUNG Mobile USB Serial Port
Phone not found
Type *#0808# and select "DM + MODEM + ADB" but don't close the window even if you clicked ok as it turns out it will not save it (at least it did so to me) just leave it on screen.
Try again to read codes and if you get:
Please wait, calculating codes... OK (time - 00:00:40)
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
use direct unlock because as you can see NCK is not displayed. If it's shown then obviously use it.
Good luck everybody.
The Following 2 Users Say Thank You to ontopgsm For This Useful Post:
Old 01-01-2014, 08:15   #12 (permalink)
Member: 2071945
can't unlcoker s7390
hi
I can't unlocker s7390 with Samsung tool 16.7.
I can read but when i click unlock he said me
how to unlock samsung S7390 version 4.1.2?
how to manual root?
Selected port: COM22 Z3X BOX Serial Port
Model: GT-S7390
IMEI: 358xxxxxxxxxxx
Phone S/N: R21D93KYFAN
Done with Samsung Tool v.16.7
who can help me
Old 01-08-2014, 07:48   #13 (permalink)
Member: 512503
Use this for root:
http://cdnpic.mgyun.com/files/produc...4388_Setup.exe
Selected port: COM13 Z3X BOX Serial Port
Model: GT-S7390
Phone version: S7390XXUAMJ5
PDA version: S7390XXUAMJ3
CSC version: S7390ORLAMJ1
IMEI: 358599052985412
Phone S/N: R21DABA9FJD
Unlocking... OK
Unlock done
Done with Samsung Tool v.16.8
Old 01-11-2014, 11:26   #14 (permalink)
mustafa_180's Avatar
Member: 638097
Sonork: 100.1649741
Thanks Meter: 42
Originally Posted by golumbu View Post
Hy,
Sir when i try to root my s7390 by this Impactor its showing (Signature Bugs Unabailable ) whats my falt plz guyd me .Thanks .
Old 01-11-2014, 14:21   #15 (permalink)
Member: 832334
Page generated in 0.52476 seconds with 7 queries
