12-05-2017, 05:38 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: PhnomPenh Cambodia
Member: 846616 Status: Offline Sonork: 100.1675590 Thanks Meter: 581 | S7EDGE AT&T Unlock Done but take 5 credits UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G935A Software version: 30.1 Checking Login and Password... OK Ballance: 36 crd. You have 36 credit(s) left. This opreratin takes 5 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SM-G935A Android version: 7.0 Product code: SM-G935AEDAATT Phone version: G935AUVU4APK1 PDA version: G935AUCS4BQE1 CSC version: G935AATT4BQE1 CSC country code: USA CSC sales code: ATT HW version: REV0.7 Phone SN: RF8H724GVBY Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-05-01 RF cal date: 2016.07.21 IMEI: 352717080231924 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM3 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 07061473 NET lock: 81582624 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.1 |
The Following User Says Thank You to kjava For This Useful Post: |
