04-01-2018, 06:52 | #7 (permalink) | |
No Life Poster Join Date: Jan 2018
Member: 2802156 Status: Offline Thanks Meter: 173 | Quote:
ALSO DO NOT ROOT you will trip knox and turn phone into a wifi tablet aka no imei ever. flash eng root for g950F, here is g955f incase anyone needs but need engroot for your phone specifically and bit rev [ENG-ROOT] kernel For Galaxy S8+ SM-G955F after flash stock firmware write eng root, then repair DRK then you can mess with combination and fix your imei, but repair drk 1st if anyone has eng ROOT (not engboot from combo) for g950F please kindly share | |
The Following User Says Thank You to gsm_service4u For This Useful Post: |
04-03-2018, 00:14 | #9 (permalink) | |
Freak Poster Join Date: Jan 2014 Location: WhereEver
Member: 2109940 Status: Offline Thanks Meter: 490 | Quote:
Do not write useless words without knowledge Combination firmware does not check for drk state Drk will never make a phone stuck ok the second logo If you took an empty board and flash combination firmware its will boot up then you can write drk hashs | |
04-03-2018, 01:21 | #10 (permalink) | |
After I received a g950f which has wiped efs, I wrote all available combination files to it, it didn't boot all the way, rather stuck on 2nd logo as I described in above post. Knox was 0x0 btw Additionally, I tried wiping data/cache then rebooting to bootloader before writing combination | |
04-05-2018, 22:13 | #11 (permalink) | |
But i know how android system works | |
