07-21-2017, 08:13 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: india Age: 40
Member: 776810 Status: Offline Sonork: 100.1627706 Thanks Meter: 19 | S8+ g955u unlock via server sucsess Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G955U Selected port: COM1 Communications Port Software version: 28.8.1 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-G955U Android version: 7.0 Product code: SM-G955UZSAATT Phone version: G955USQU1AQDE PDA version: G955USQU1AQDE CSC version: G955UOYN1AQDE CSC country code: USA CSC sales code: ATT HW version: REV1.0 Phone SN: R38J402W2MX Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-04-01 RF cal date: 2017.04.04 IMEI: Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM3 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 84746253 NET lock: 25794182 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.8.1 |
The Following User Says Thank You to firose4u For This Useful Post: |
07-21-2017, 14:26 | #3 (permalink) | |
Junior Member Join Date: Jul 2014
Member: 2224244 Status: Offline Thanks Meter: 2 | Quote:
is this with z3x or other? | |
