04-29-2012, 10:40 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Age: 14
Member: 1214273 Status: Offline Thanks Meter: 136 | S8500 and Read Headinfo Fail Log from IMEI repair: Code: Searching Samsung USB Modem... Detected (COM18) Reading Phone Info... OK Model: GT-S8500 SW: S8500XEJH2 IMEI: ERROR Read Headinfo Fail Code: Searching Samsung USB Modem... Detected (COM18) Reading Phone Info... OK Model: GT-S8500 SW: S8500XEJH2 IMEI: ERROR Unique Number: Cant Set Security Mode |
04-29-2012, 11:49 | #4 (permalink) |
Member: 1214273 Status: Offline Thanks Meter: 136 | Yes, I try repair IMEI as log above but unfortunately error incoming. Maybe EFS, I don't know. Phone was erased with JTAG then resurrecting and upgrading FW to bada 1.2. How check if EFS is damaged or how repair ? |
04-29-2012, 14:19 | #7 (permalink) |
Member: 1214273 Status: Offline Thanks Meter: 136 | Searching Samsung USB Modem... Detected (COM82) Reading Phone Info... OK Model: GT-S8500 SW: S8500XEJH2 IMEI: ERROR Factory SW: Unique Number: Cant Set Security Mode Done with Samsung Tool ver 11.9 after next repeat about 2 seconds other error Reading Phone Info... OK Model: GT-S8500 SW: S8500XEJH2 IMEI: ERROR Factory SW: Unique Number: Phone SN: 0000000000 Bypass MSL... Error, Flash Patched Firmware First (already flashed withS8500_XEJH2_Patched_for_Unlock_and_IMEI_v2.crp twice) Done with Samsung Tool ver 11.9 |
04-29-2012, 14:48 | #8 (permalink) |
Member: 1214273 Status: Offline Thanks Meter: 136 | Log from patch write: Searching Samsung USB Flash Interface... detected (COM18) Loading File... OK Model: S8500 Version: S8500XEJH2 Info: Patched for Unlock and IMEI repair v2 Sending modem... OK Sending apps... OK Sending rsrc1... OK Sending rsrc2... OK Sending fs... OK Sending csc... OK Sending app... OK Sending pfs... OK Flashing Done (time - 00:09:28) Done with Samsung Tool ver 12.4 |
04-29-2012, 14:57 | #9 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Romania Age: 41
Member: 1722871 Status: Offline Thanks Meter: 116 | 1. Maybe the phone has a hardware problem. I read that if I9100 has a blank IMEI can be a crack in the chip RFIC (U100). 2. If is not an hw problem, maybe the best thing is to try full dump from an working S8500 EFS and write it in the damaged phone with JTAG. I am new to this so I cant say much about. I only read about this kind of solution. If work then try to repair the IMEI with z3x. 3. I think downgradeing z3x software is not a solution. Try only with 12.4 4. After writing that patch firmware always do a factory reset with *2767*3855# |
04-29-2012, 15:18 | #10 (permalink) | |
Member: 1214273 Status: Offline Thanks Meter: 136 | Quote:
04-29-2012, 15:40 | #11 (permalink) |
Member: 1722871 Status: Offline Thanks Meter: 116 | I saw on the forum that upgradeing with z3x is problematic, so the best choice is Multiloader 5.67 for writing the firmware with Boot Change and Full Download checked. When you are stuck at Bada logo maybe you have an option to wipe cache if it has that option and recovery mode. I didn't get may hands on to many Bada phones so I am not an expert I just know that upgradeing to Bada 2.0 is a big problem. Many phones are fried at this stupid upgrade |
04-29-2012, 16:05 | #12 (permalink) |
Member: 1214273 Status: Offline Thanks Meter: 136 | Right mate. But for IMEI repair i need to flash special patch file signed as *.crp known only for Z3X. flashing progress is correctly in both cases - with oryginal FW files and patch file. The point is why errors when trying repair IMEI. Any advice experts ? |
05-09-2012, 18:54 | #15 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | And if is not a secret,how did you repair your s8500? I have one which is giving me problems,hang on bada logo,try all version(1.0,1.2,2.0).Now I erased with riff,flashing dump from riff data exchange...waiting your answer how to proceed after that... thanks |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
