01-31-2012, 21:08 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Age: 43
Member: 978268 Status: Offline Thanks Meter: 83 | s8530 imei problem team i got s8530 for security code unlock , so i flashed it with multi-loader ,so it given error and the phone was dead and then i recoverd it , but imei is not active this is the log Count supported models - 290 Done with Samsung Tool ver 11.9 Searching Samsung USB Modem... Detected (COM101) Reading Phone Info... OK Model: GT-S8530 SW: S8530BOJL3 IMEI: ERROR Country Code: XEF Factory SW: S8530POJL3_XEFJL3 Unique Number: 76410000636998 Memory Phone: KAC007021M(S8530) Phone SN: 0000000000 Bypass MSL... Error, Flash Patched Firmware First Done with Samsung Tool ver 11.9 Searching Samsung USB Flash Interface... detected (COM66) Sending BOOT_LOADER.mbn... OK Sending Dbl.mbn... OK Flashing BOOT Files Done (time - 00:00:01) Wait, Reset... OK Sending AMSS... OK Sending APPS... OK Sending RSRC1... OK Sending RSRC2... OK Sending FFS... OK Sending CSC... OK Sending SHP APP... OK Flashing Done (time - 00:06:33) Done with Samsung Tool ver 11.9 |
06-07-2012, 18:33 | #3 (permalink) |
Banned Join Date: May 2012 Location: in ur heart Age: 32
Member: 1761678 Status: Offline Sonork: 100.1615439 Thanks Meter: 370 | use z3x select s8000 *#197328640# 8 Common 5 Usb Switch info 2 Polling mode press end call and turn main menu again *#197328640# 8 Common 6 Dummy menu 1 DIAG Diag SRVC Configured press end call and turn main menu again *#197328640# 8 Common 7 Service Configuration 2 DIAG Service 2 USB DM/CP USB ACM/CP Configured Now Connect usb then repair imei |
The Following User Says Thank You to tauheed9 For This Useful Post: |
06-22-2012, 09:11 | #4 (permalink) |
No Life Poster Join Date: Sep 2005 Location: TR-LAZ
Member: 178227 Status: Offline Sonork: 100.1597371 Thanks Meter: 176 | WEYRYY GOOOD BRO tauheed9 test ok 100 %100 ok Searching Samsung USB Modem... Detected (COM136) Reading Phone Info... OK Model: GT-S8530 SW: S8530JVJL3 IMEI: 351*********4 Country Code: XEF Factory SW: S8530XXJK9/OXAJK7 Unique Number: 76300000486708 Memory Phone: KAC007021M(S8530) Phone SN: 0000000000 Bypass MSL... Error, Flash Patched Firmware First Done with Samsung Tool ver 11.3 Searching Samsung USB Modem... Not Found Done with Samsung Tool ver 11.3 Reading Phone Info... OK Model: GT-S8530 Country Code: XEF Cal Date: 2010-11-30 Factory SW: S8530XXJK9/OXAJK7 Unique Number: 76300000486708 Memory Phone: KAC007021M(S8530) Phone S/N: R5XZC31659 Build: Q6270B-KPUBL-1.5.45082ST IMEI: 351************4 Repairing IMEI... OK New IMEI: 354*******0**6 Done with Samsung Tool ver 11.3 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
