06-20-2017, 16:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | S8530 wave II unlock, server error.. Code: Searching Samsung USB Modem... detected (COM147) Reading Phone Info... OK Model: GT-S8530 Factory SW: S8530AEKC1_SFRKC1 CountryCode: SFR UniqueNumber: 86220000744639 MemoryPhone: KAC007021M(S8530) SW: S8530BVKA1 IMEI: 35888804422766/4 Reading SysInfo... OK Searching server... Error Done with Samsung 3G tool ver 9.4 Code: UNLOCK INSTRUCTIONS: USB mode : 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Samsung mode 3. Connect phone to PC, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Or you can 'Read User Lock' or 'Reset User Lock'. Operation: Unlock Selected model: GT-S8530 Software version: 28.2 Searching Samsung modem... detected COM147 Reading phone info... Model: GT-S8530 Country code: اء¶û½؛ Cal date: 2011-03-29 Factory SW: S8530AEKC1_SFRKC Unique number: 86220000744639 Memory phone: KAC007021M(S8530) Reading SYSINFO... Ok Searching server... error (timeout) Done with Samsung Tool PRO v.28.2 is this phone still supported by z3x ? br |
06-20-2017, 18:16 | #2 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | done with v20.5 Code: UNLOCK INSTRUCTIONS: USB mode : 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Samsung mode 3. Connect phone to PC, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Or you can 'Read User Lock' or 'Reset User Lock'. Operation: Unlock Selected model: GT-S8530 Software version: 20.5 Searching Samsung modem... detected COM147 Reading phone info... Model: GT-S8530 Country code: اء¶û½؛ Cal date: 2011-03-29 Factory SW: S8530AEKC1_SFRKC Unique number: 86220000744639 Memory phone: KAC007021M(S8530) Reading sysinfo... OK Searching server... OK Writing sysinfo... OK Reseting... OK Unlock done [Update] Your firmware DB will be updated after model change or software restart. Done with Samsung Tool v.20.5 |
The Following User Says Thank You to .:bono:. For This Useful Post: |
