05-08-2020, 19:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | S9 carrier CRICKET UNLOCK DONE STILL BEST Z3x Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking TMB using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Unlocking SPR using sever: 1. Insert not SPR card to the phone and power it on. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock...' button, select 'Unlock SPR via Server', write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G960U Software version: 40.0 Checking Login and Password... OK Ballance: 32 crd. You have 32 credit(s) left. This operation takes 8 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G960U Android version: 10 PDA version: G960USQU7DTA8 CSC version: G960UOYN7DTA8 Phone version: G960USQU7DTA8 Product code: SM-G960UZKAAIO CSC country code: USA CSC sales code: AIO Phone SN: R38K70SL40R IMEI: 353xxxxxxxxxxxx HW version: REV1.1 RF cal date: 2018.07.27 Chip name: SDM845 Modem board: SDM845 Security patch: 2020-02-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching Samsung diag port... detected COM83 Reading phone info... OK Reading data from phone... OK Searching Ramdump interface... COM23 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 61619395 NET lock: 17507084 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.40.0 |
The Following User Says Thank You to ghacks For This Useful Post: |
