04-30-2020, 16:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Algéria
Member: 484595 Status: Offline Thanks Meter: 39 | Sam SM-A705fn error write flash [Answered] ITS SAY RED LIGNEE CUSTOM BINARY SYSTME BLOCKED RU OEM ON FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.up + vol.down and insert USB cable). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A705FN Software version: 39.9 File analysis... OK Total file size: 0x1934055DC (6452 Mb) Searching USB Flash interface... COM6 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending abl.elf.lz4... OK Sending xbl.elf.lz4... OK Sending xbl_config.elf.lz4... OK Sending tz.mbn.lz4... OK Sending hyp.mbn.lz4... OK Sending devcfg.mbn.lz4... OK Sending aop.mbn.lz4... OK Sending bksecapp.mbn.lz4... OK Sending cmnlib.mbn.lz4... OK Sending cmnlib64.mbn.lz4... OK Sending keymaster64.mbn.lz4... OK Sending vaultkeeper.mbn.lz4... OK Sending qupv3fw.elf.lz4... OK Sending sec.elf.lz4... OK Sending apdp.mbn.lz4... OK Sending msadp.mbn.lz4... OK Sending storsec.mbn.lz4... OK Sending NON-HLOS.bin.lz4... OK Sending dspso.bin.lz4... OK Sending uefi_sec.mbn.lz4... OK Sending vbmeta.img.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending vendor.img.ext4.lz4... OK Sending system.img.ext4.lz4... error timeout Done with Samsung Tool PRO v.39.9 |
12-27-2020, 17:23 | #4 (permalink) |
Insane Poster Join Date: Oct 2005
Member: 193082 Status: Offline Thanks Meter: 3 | Hello, I have a similar problem. I need remove FRP. - firmware in my phone (A705FN/DS) - A705FNXXU5BTJ4 - i try flash this combination files COMBINATION_FAC_FA90_A705FNXXU5ATA3_FACFAC_CL16099 365_QB28522265_REV00_user_mid_noship_MULTI_CERT.ta r.md5 - and problem is here Operation: Flash Selected model: SM-A705FN Software version: 41.11 File analysis... OK Total file size: 0xAD3B9DE4 (2771 Mb) Searching USB Flash interface... COM17 detected Setup connection... OK Set PIT file... Error Done with Samsung Tool PRO v.41.11 |
