06-18-2011, 19:56 | #91 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 54
Member: 61156 Status: Offline Thanks Meter: 105 | add this version for sam c3500.see the logs: ------------------------------------------------------------------------------- Selected model: C3500 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3500XXKB2 Phone CSC: C3500OXAKB1 Phone BT ADDR: 2013-E0-70F6B6 Phone IMEI: 35402804088116 Deactivated MSL - FAIL Elapsed time: 45 second, sw ver: 3.5.0022.. the same result with read info als direct unlock..thank you master |
06-18-2011, 23:02 | #92 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sahara Desert Age: 77
Member: 150570 Status: Offline Thanks Meter: 52 | Using micro uart cable does the trick. Took a few attempts to connect in tat mode. Make certain cable is well inserted into phone's connection/port and then press power on.. Phone will be unlocked. When you insert different sim card, phone will come up with network code required window. Just insert 8 zero's and phone will be unlocked. This is the Second c3300k that I've attempted to unlock. Thank goodness it eventually worked/unlocked Marty |
06-19-2011, 19:12 | #95 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
08-21-2011, 08:29 | #100 (permalink) | |
Banned Join Date: Sep 2008 Location: in ur dreams
Member: 867442 Status: Offline Sonork: 100.1602740 Thanks Meter: 143 | c3222 phone lock code problem Quote:
t phone and press power button 3 seconds Timeout Phone fail TAT MODE Deactivated MSL - FAIL Aborted by user Elapsed time: 33 second, sw ver: 3.5.0026 ------------------------------------------------------------------------------- Selected model: C3222 Selected com port: COM5 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 34 second, sw ver: 3.5.0026 ------------------------------------------------------------------------------- Selected model: C3222 Selected com port: COM5 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... Aborted by user Elapsed time: 30 second, sw ver: 3.5.0026 ------------------------------------------------------------------------------- Selected model: C3222 Selected com port: COM5 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... FAIL Send loaders - fail Elapsed time: 47 second, sw ver: 3.5.0026 http://forum.gsmhosting.com/vbb/f453...c3222-1184338/ | |
08-31-2011, 16:27 | #103 (permalink) |
No Life Poster Join Date: Feb 2009 Location: nicaragua
Member: 980307 Status: Offline Sonork: 100.1649165 Thanks Meter: 173 | please i need help blang... i have one samsung c3500 i need flash the phone whit z3x box whith other program not found or not conect i need please supported phone for flash.. thanks... |
OT706 Bug in 263? [SOLVED] | ..::SuB::.. | PolarBox 3 | 3 | 06-16-2011 13:04 |
