11-15-2016, 14:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | samsung 5610k restart Selected model: GT-S5610K Software version: 27.1 Load model info... ok Loading BIN PTT file... ok Loading CSC PTT file... ok Reconnect battery and connect phone to USB cable Phone detected Checking device descriptions... ok Link type set to USBH Reading OTP... ok OTP register: 00000000 Unprotected device detected Reading product ID... ok Product ID: 0x 6767581 E50562F Reading SCROM version SCROM version - PNX6729 v. 1.10 Chipset version - 3C11 Downloading Loader in Internal RAM... ok Wait for device... ok Checking device descriptions... ok Loader verison... 7.5.16 NAND flash memory SSG_K522H1HACA-A060 detected Flash memory parameters Capacity params: 2 Datawidth - 2048 Block number - 64 Block size - 0 Buffer prog. Timing params: 2 ms erase block time - 250 us write buffer time Send Loader and NAND Flash Parameters... Loader parameters Write Test flash params: 0x0 Test Address - 0 Test size Buffer params: 3 Buffer type - 134217728 Buffer size - 32768 Tansfert size - 32768 Tansfert RAW size Bad Block params: 42 Bad block reservoir size SW Boot version: 5 Get First Block... ok Prepare FirstBlock... ok Init Bad Block Managment... ok Send Verify Cmd... ok Erasing Partition_1... ok Erasing Partition_2... ok Erasing Partition_3... ok Erasing Partition_4... ok Erasing Partition_5... ok Erasing Partition_6... ok Erasing Partition_7... ok Erasing Partition_8... ok Check Protected Device... ok Programming Partition_1 Prepare CRC32... ok Set Partition Params... ok Download Partition_1 IMAGE... ok Checking CRC32... ok Programming Partition_2 Prepare CRC32... ok Set Partition Params... ok Download Partition_2 LCDACT... ok Checking CRC32... ok Programming Partition_3 Prepare CRC32... ok Set Partition Params... ok Download Partition_3 MAIN... ok Checking CRC32... ok Programming Partition_4 Prepare CRC32... ok Set Partition Params... ok Download Partition_4 PAGED... ok Checking CRC32... ok Programming Partition_5 Prepare CRC32... ok Set Partition Params... ok Download Partition_5 a... ok Checking CRC32... ok Programming Partition_6 Prepare CRC32... ok Set Partition Params... ok Download Partition_6 b... ok Checking CRC32... ok Programming Partition_7 Prepare CRC32... ok Set Partition Params... ok Download Partition_7 c... ok Checking CRC32... ok Programming Partition_8 Prepare CRC32... ok Set Partition Params... ok Download Partition_8 d... ok Checking CRC32... ok Updating RCB... ok Flashing done (time - 00:01:55) Done with Samsung Tool PRO v.27.1 software done but not solve restart. any solution sir |
