01-04-2017, 12:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2015 Location: India
Member: 2366206 Status: Offline Sonork: 100.1666898 Thanks Meter: 138 | Samsung a300f unlock done with z3x Reading IMEI... Ok IMEI: 357258***** Unlocking... Ok Reseting... Ok Unlock done Done with Samsung Tool PRO v.27.6 |
08-09-2017, 13:09 | #3 (permalink) |
Member: 2366206 Status: Offline Sonork: 100.1666898 Thanks Meter: 138 | samsung a300f unlock Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC' (ignore it, if it's not available). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. |
The Following User Says Thank You to RAJAN BHAGORIYA For This Useful Post: |
08-14-2017, 07:18 | #6 (permalink) | |
Freak Poster Join Date: May 2007 Age: 25
Member: 503942 Status: Offline Thanks Meter: 61 | Quote:
You need to downgrade modem firmware from ver 5.0.2. Find firmware 5.0.2 with binary counter matching to your and downgrade only modem. Unlock and then restore modem to 6.0.1. 100% work so many times that i can't count :-) | |
The Following User Says Thank You to suchywilk For This Useful Post: |
