06-16-2016, 09:52 | #1 (permalink) |
Freak Poster Join Date: Jan 2012 Location: italia
Member: 1713998 Status: Offline Thanks Meter: 16 | Samsung A5 dead after flash with z3x FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A500FU Software version: 25.5 File analysis... OK Total file size: 0x79F93364 (1951 Mb) Searching USB Flash Interface... detected COM32 Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending NON-HLOS.bin... OK Sending rpm.mbn... OK Sending sbl1.mbn... OK Sending tz.mbn... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending modem.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:03:46) Done with Samsung Tool PR flash with thes file A500FUXXU1ANL6_A500FUOXX1AOA1_A500FUXXU1ANL5_HOME. tar download z3x supprt |
The Following User Says Thank You to haninasr For This Useful Post: |
06-16-2016, 15:34 | #2 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Online Thanks Meter: 253 | Most likely you downgraded firmware from 5.0 to 4.4.4. It can't be done with that models. There should be a way to recover it, but it requires you to open the devices and force it: http://forum.gsmhosting.com/vbb/f672...5-etc-2008827/ |
The Following User Says Thank You to KrzychuG For This Useful Post: |
