12-03-2017, 05:46 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Bangladesh
Member: 1845954 Status: Offline Sonork: 100.1622497 Thanks Meter: 397 | Samsung A500F cert write problem Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-A500F Selected port: COM416 SAMSUNG Mobile USB Serial Port Software version: 30.1 Checking CERT file... OK KEY ID: 0756 Waiting ADB device... OK Reading phone info... Model: SM-A500F Android version: 5.0.2 Product code: SM-A5000ZWATGY Phone version: A5000ZHU1BOL3 PDA version: A500FXXU1BOL3 CSC version: A500FOJV1BOL3 CSC country code: Hong Kong CSC sales code: TGY HW version: MP1.101 Phone SN: R28H91G766F Modem board: MSM8926 Security patch: 2015-12-01 RF cal date: 2016.09.14 IMEI: 2515925302514f0 Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... error (2) First reset MSL Done with Samsung Tool PRO v.30.1 When try Reset Msl than show Reading phone info... Reading IMEI... OK IMEI: xxxxxxxxxxxxxx Reseting MSL security... error (1) Done with Samsung Tool PRO v.30.1 |
12-03-2017, 14:04 | #3 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hi, try to downgrade the firmware to the Android 5.0.2 version of the older security patch level. Since you have the firmware installed the Android phone 5.0.2 with security patch level of December, try to degrade the patch level you security Making the flash of another firmware with security patches before October 2015 did this, try rewriting the certificate in the phone and see if it writes it correctly |
