04-29-2015, 14:08 | #7 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2134278 Status: Offline Thanks Meter: 19 | a500f sapprot Direct Unlock with install_octoplus_octopus_Samsung_1.9.3 Cable: Micro USB Samsung SM-A500F (Galaxy A5) 1. Available operations 2. Cables for connection 3. Necessary drivers 4. Write Firmware 5. Direct Unlock 6. Repair EFS 7. Read QCN 8. Write QCN 9. Write Certificate 10. Wipe Security 11. Download Mode 12. FAQ 1. Available operations Read Info (cable: Micro USB); Write Firmware (cable: Micro USB); Read NVM (cable: Micro USB); Write NVM (cable: Micro USB); Repair NVM (cable: Micro USB); Direct Unlock (cable: Micro USB); Repair EFS (cable: Micro USB); Read QCN (cable: Micro USB); Write QCN (cable: Micro USB); Write Certificate (cable: Micro USB); Wipe Security (cable: Micro USB). Back to main menu 2. Cables for connection Micro USB cable Back to main menu Samsung Micro UART cable Back to main menu 3. Necessary drivers For correct work with the phone install "SAMSUNG USB Driver for Mobile Phones" driver. Back to main menu 4. Write Firmware Put phone into Download Mode. Connect the phone to PC via Micro USB cable. Install required driver. Select firmware file. Click "Write firmware" button. Follow software instructions (prompts). Note: Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don't turn off phone and don't disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage. Back to main menu 5. Direct Unlock Connect powered-on phone to PC via Micro USB cable. Install necessary driver. Click "Unlock" button. Follow software instructions (prompts). Back to main menu 6. Repair EFS Put phone into Download Mode Connect the phone to PC via Micro USB cable. Install required driver. Click "Repair EFS" button. Follow software instructions (prompts). Back to main menu 7. Read QCN Connect powered-on phone to PC via Micro USB cable. Install necessary driver. Click "Read QCN" button. Follow software instructions (prompts). Back to main menu 8. Write QCN Connect powered-on phone to PC via Micro USB cable. Install necessary driver. Click "Write QCN" button. Follow software instructions (prompts). Back to main menu 9. Write Certificate Root your phone manually. Wipe Security Connect powered-on phone to PC via Micro USB cable. Install necessary driver. Click "Write Cert" button. Follow software instructions (prompts). Back to main menu 10. Wipe Security Root your phone manually. Connect powered-on phone to PC via Micro USB cable. Install necessary driver. Click "Repair Security/Wipe Security" button. Follow software instructions (prompts). Back to main menu 11. Download Mode To enter Download Mode, reconnect the battery, press and hold "Volume down" + "Volume up" and connect USB cable. Back to main menu 12. FAQ Q: My phone not found by program. How can I configure my phone? A: Provide following steps: Disconnect USB cable from phone (if connected). Go to Menu->Settings->Applications->Development. Turn on "USB Debugging" option. When message is appear press "Yes". Press "Read Info" in Octopus Samsung software. Back to main menu Report Post |
