10-23-2017, 05:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: vietnam
Member: 259188 Status: Offline Thanks Meter: 79 | SM-A500H Only Gsm No 3g.how i can fix 3g network phone downgrade 4.4.4 full file not ok. what can i do? i need help to fix this problem.how i can fix 3g network? |
The Following User Says Thank You to jimmymobile For This Useful Post: |
10-23-2017, 06:42 | #2 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | repair efs to fix bb also check your cert if is ok.. if is not write a good cert file |
The Following User Says Thank You to yuranc8 For This Useful Post: |
10-24-2017, 05:54 | #6 (permalink) | |
Member: 259188 Status: Offline Thanks Meter: 79 | Quote: network show Lte/3g/2g auto but reset the phone or change sim phone back to the same network (wcdma/gsm) | |
10-24-2017, 06:15 | #7 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | i think that is normal i checked new phone which has 4g it was set on gsm instead of gsm and wcdma and lte |
The Following User Says Thank You to profkefah For This Useful Post: |
10-24-2017, 10:15 | #11 (permalink) |
Freak Poster Join Date: May 2017 Location: Ghazni city-Afghanistan
Member: 2717040 Status: Offline Thanks Meter: 32 | ferst root your phone and install rootbrowser open rootbrowser rename CSC folder. solve your phone problem. |
The Following User Says Thank You to Reha GSM For This Useful Post: |
11-17-2018, 09:26 | #12 (permalink) |
Insane Poster Join Date: Jul 2017 Location: Bangladesh Age: 29
Member: 2740295 Status: Offline Thanks Meter: 33 | Reading QCN file... OK Reading ID... OK Detected ID: 000000F8 (Unknown) SW version: MPSS.DPM.1.0.c7.1-00169-M8916EAAAANVZM-1 Incorrect model selected. This may damage your phone. Continue? Yes Checking paths... OK Restoring EFS backup... error (0) Done with Samsung Tool PRO v.34.2 |
The Following User Says Thank You to raju24.bd For This Useful Post: |
