07-11-2017, 13:43 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,075 | Samsung A510f 7.0 Unlock Success Z3X Reading phone info... Model: SM-A510F Android version: 7.0 Product code: SM-A510FZKFMID Phone version: A510F PDA version: A510FXXS4CQF1 CSC version: A510F CSC country code: Iraq CSC sales code: MID HW version: MP 0.000 Phone SN: R58J30NPB8B Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-06-01 RF cal date: 20170303 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: B8 82 E8 23 EE CE 21 C3 FA 19 8A 1D 3F 63 D7 37 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.6 |
07-11-2017, 20:53 | #2 (permalink) |
Junior Member Join Date: Oct 2009 Location: PGC Jakarta Indonesia
Member: 1150135 Status: Offline Sonork: https://www.facebook.com/ Thanks Meter: 6 | UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Pattern lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-A510F Software version: 28.6 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-A510F Android version: 6.0.1 Product code: SM-A510FZKDVD2 Phone version: A510FXXU4BQC3 PDA version: A510FXXU4BQC1 CSC version: A510FVFG4BQC3 CSC country code: Germany CSC sales code: VD2 HW version: MP 0.200 Phone SN: R58J43DGQ3F Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 RF cal date: 20170420 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 8A CA A2 BB 20 5A 52 09 AB AA D0 34 B9 5C A2 B6 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.28.6 |
The Following 2 Users Say Thank You to jayakusniadi For This Useful Post: |
07-11-2017, 20:55 | #3 (permalink) |
Member: 1150135 Status: Offline Sonork: https://www.facebook.com/ Thanks Meter: 6 | DOWNGRADE 7 to 6.0.1 https://drive.google.com/uc?id=0B5Sf...xport=download ROOT https://download.chainfire.eu/937/CF...etrieve_file=1 UNLOCK VIA Z3X DONE |
The Following User Says Thank You to jayakusniadi For This Useful Post: |
02-11-2018, 14:20 | #4 (permalink) |
Junior Member Join Date: May 2010 Location: sylhet Age: 36
Member: 1299854 Status: Offline Thanks Meter: 12 | Samsung A510f 7.0 root file Unlock Success Z3X samsung A510F 7.0 root file 100% warking Operation: Unlock Selected model: SM-A510F Software version: 30.7 Waiting ADB device... OK Reading phone info... Model: SM-A510F Android version: 7.0 Product code: SM-A510FZWAXEU Phone version: A510FXXU4CQH2 PDA version: A510FXXU4CQH2 CSC version: A510FXEU4CQH2 CSC country code: UK & IRE CSC sales code: XEU HW version: MP 0.200 Phone SN: RF8J100S6QJ Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-08-01 RF cal date: 20170102 IMEI: 354361088124993 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: CE 9B 7A 25 67 38 97 A8 D9 6D 63 83 28 25 83 D2 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.7 samsung A510F 7.0 root file download https://download.chainfire.eu/937/CF...xx-sma510f.zip |
The Following User Says Thank You to belalsylheti For This Useful Post: |
02-10-2019, 18:33 | #5 (permalink) | |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | New Sec. Not Successfully, also not supported to downgrade modem! Quote:
02-10-2019, 20:11 | #6 (permalink) |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Hello, having on the new firmware the recent security patches the unlock is not supported, install the combination or eng modem binary 7 for a510f and repeat the unlock operation with z3x software and see if the network on the phone is unlocked . |
02-11-2019, 15:28 | #7 (permalink) | |
Member: 5184 Status: Offline Thanks Meter: 246 | Quote:
No, This Combination FAC File is not help in case. I Unlocked it easy / B7 / S7 / U7 Binary. Flash custom recovery ... .tar Install Super SU....zip Now phone rooted successfully. Use latest version Z3x Press Unlock NEW Done Log Code: Waiting ADB device... OK Reading phone info... Model: SM-A510F Android version: 7.0 PDA version: A510FXXS7CRK1 CSC version: A510FOJV7CRK1 Phone version: A510FDXXU7CRK2 Product code: SM-A510FZWDTUR CSC country code: TURKEY CSC sales code: TUR Phone SN: IMEI: HW version: MP 0.200 RF cal date: 20161104 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2018-11-01 Boot Warranty bit: 1 SIM State: NOT_READY,ABSENT Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... OK Reading data... OK HWID: 28 FA E4 B7 AD AC 77 29 26 AB 3C 46 B5 26 9C 86 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.34.8 | |
