09-24-2018, 08:14 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | Samsung a510fd after flash combination power reser or unknown mode upload mode COMBINATION_FAC_FA51_A510FDXXU5ARB1 phone was binary 4 so i flashed latest binary 5 now phone stuck on upload mode FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A510FD Software version: 33.8 File analysis... OK Total file size: 0x0225D460 (34 Mb) Searching USB Flash interface... COM41 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Flashing done (time - 00:00:0 Done with Samsung Tool PRO v.33.8 |
09-24-2018, 08:27 | #3 (permalink) | |
Member: 2478233 Status: Offline Thanks Meter: 596 | Quote:
give me link of tested and latest file | |
09-24-2018, 11:15 | #15 (permalink) |
Member: 2478233 Status: Offline Thanks Meter: 596 | <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/041> Added!! <ID:0/041> Odin engine v(ID:3.1301).. <ID:0/041> File analysis.. <ID:0/041> Total Binary size: 2920 M <ID:0/041> SetupConnection.. <ID:0/041> Initialzation.. <ID:0/041> Get PIT for mapping.. <ID:0/041> Firmware update start.. <ID:0/041> NAND Write Start!! <ID:0/041> SingleDownload. <ID:0/041> sboot.bin <ID:0/041> cm.bin <ID:0/041> boot.img <ID:0/041> recovery.img <ID:0/041> system.img <ID:0/041> cache.img <ID:0/041> hidden.img <ID:0/041> modem.bin <ID:0/041> RQT_CLOSE !! <ID:0/041> RES OK !! <ID:0/041> Removed!! <ID:0/041> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/078> Added!! solved by flashing latest firmware from sammobile binary 6 firmware now frp locked now need frp solution |
