02-28-2018, 13:37 | #1 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Syrian-Egypt Age: 26
Member: 2539108 Status: Offline Thanks Meter: 239 | Galaxy note 8 N950F Unlock Done Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Operation: Read Codes via Server Selected model: SM-N950F Software version: 30.8 Checking Login and Password... OK Ballance: 45 crd. You have 45 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM156 Reading phone info... OK Model: SM-N950F AP version: N950FXXU3BRA8 CSC version: N950FOXM2BRA1 CP version: N950FXXU3ARA1 Product code: NEE Phone SN: R58J849J2WH Unique number: CE06171640639CAB0C7E Searching Samsung diag port... detected COM155 Reading phone info... OK CP version: N950FXXU3ARA1 CP build: Jan 9 2018 14:30:26 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 13742420 NET lock: 28585082 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.8 |
The Following User Says Thank You to HassanMahainiy For This Useful Post: |
