Old 05-18-2011, 09:05   #1 (permalink)
Member: 154932
SAMSUNG A777 very hard to unlock why?
I already installed drivers, also I used Samsung Qualcomm 6.4.05, cable used e210 & j750. Any help Mr Blang & members, Please?.....
Count supported models - 223
Searching Samsung USB interface... not found
No answer from phone
Done with Samsung 3G tool ver 9.4
Model: A777
CountryCode: ATT
Factory SW: A777UCHI5
UniqueNumber: 55310000137947
MemoryPhone: TYA000B800DO(A777)
IMEI: 3589xxxxxxxxxxxx
Phone S/N: RPPS373838
Build: M6260A-KYRZ-2.5.1033_4S
Model: A777
CountryCode: ATT
Reading SysInfo... OK
Calculating... error
Searching SysInfo... error
Old 05-18-2011, 09:08   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Model: A777
CountryCode: ATT
Model: A777
CountryCode: ATT
do you read manual inside sofware?
Old 05-18-2011, 09:09   #3 (permalink)
*miguel05_gsm*'s Avatar
Member: 1453900
follow this bro...
Qualcom mode method (only usb):
1. Power on phone.
2. Type *#197328640# -> common -> usb config -> Qualcomm mode
3. Connect USB part of 2in1 cable, setup drivers.
4. Choise qualcomm diagnostic port in port settings.
5. Choise unlock method: Read codes or Direct.
6. Press Unlock SP button.
Samsung mode method (2in1 cable):
1. Power on phone.
2. Type *#197328640# -> common -> usb config -> Samsung mode
3. Connect 2in1 cable, setup drivers.
4. Choise port of RJ45 connector in port settings
goodluck...
The Following User Says Thank You to *miguel05_gsm* For This Useful Post:
Old 05-18-2011, 09:38   #4 (permalink)
Member: 154932
Yes Mr Blang I read & follow the manual from Qualcom mode & Samsung mode but same errors.
Old 05-18-2011, 09:44   #5 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
where is each log? qualcomm mode and samsung mode?
Old 05-18-2011, 10:03   #6 (permalink)
Member: 154932
sir this is for qualcomm
Preved!
Count supported models - 146
Server news:
[25.04.2011]
Samsung 2G Tool 3.5.0015.
Add model ر3060 read code unlock imei.
Add model E2530, E2330 repair imei.
[16.03.2011]
New shell released. Bugfix with card repair and reader drivers added.
[8.02.2011]
China Editor 5.2 released!
[13.01.2011]
Samsung 3G tool 9.2 released!
[20.11.2010]
LG Qualcomm Tool 2.1.1 released!
Same unreal update
[24.06.2010]
LG 2g Tool 1.1.0beta released! Added GM15x series
READ NEWS FOR DETAILS!
Searching Qualcomm USB interface... detected (COM19)
IMEI: 35501903770176
SW: M6290A-K
SW: M6290A-K
Unlock as MSL2 Direct... error (Cant read UniqueNumber)
Old 05-18-2011, 10:19   #7 (permalink)
Member: 139251
Try to unlock with inserted sim,
Old 05-18-2011, 10:23   #8 (permalink)
Member: 154932
thanks but the same error
Old 05-18-2011, 10:29   #9 (permalink)
Member: 139251
Also try to use lower version of 3G tool, try version 8.3
Old 05-18-2011, 11:08   #10 (permalink)
Member: 154932
finally i got it at version 8.2. thanks to you friend very much appreciated, just noted to Mr Blang that current version 9.4 not unlock this model.
Model: A777
CountryCode: ATT
IMEI: 358xxxxxxxxxxxxx
Calculating... OK
Bypass MSL... OK
Unlocking... OK (time - 00:00:16)
Model: A777
CountryCode: ATT
IMEI: 35xxxxxxxxxxxxxxx
Calculating... OK
Calculating codes... OK (time - 00:00:28)
Freeze code: 35285737
NET lock: #7465625*638*70614057#
Sub lock: #7465625*782*00000000#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
Multi lock: #7465625*685*12369874#
SIM lock: #7465625*746*12369874#
For check lock status: *#7465625#
Old 09-08-2011, 18:08   #11 (permalink)
Member: 169056
pls dun2 were can download version 8.2
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 1.01717 seconds with 11 queries
