12-02-2015, 12:10 | #1 (permalink) |
Freak Poster Join Date: Jul 2013 Location: Mandaue City, Cebu
Member: 1986646 Status: Offline Thanks Meter: 100 | Samsung A8 SM-A800F 5.1.1 Unlock Phone must be rooted! For Root Instructions refer to this link: http://rooter15.********.com/2015/08...galaxy-a8.html Make sure OEM is on in Developer Options. Reactivation Lock is Off also. After flashing tar file using odin. Download superuser in playstore then install. Root is done. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press Read Codes Insert other carrier sim and input unlock code. Done |
The Following User Says Thank You to freesoul22 For This Useful Post: |
