Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jun 2010 Location: Italy Age: 35
Member: 1332352 Status: Offline Thanks Meter: 2 | Samsung B5722 - EEPROM REPAIR after 3 days of research and tries, finally i've find a correct epprom file to write to this phone (not available in z3x support!), avoiding the error message bd0204ee. ![]() However, now i've to repair epprom to fill correct imei on the phone, so please if the supporter can tell to us a work solution we'll appreciate very much. This is the box log: ------------------------------------------------------------ Selected model: B5722_m Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Phone IMEI -> 00000000000000 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> [NET LOCK]: [SIM LOCK]: [PHONE LOCK]: [SP LOCK]: Read Info - ok Elapsed time: 80 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Selected model: B5722_m Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Repair IMEI block Repair IMEI block Repair IMEI block Repair IMEI block timeout Send NOR - fail Elapsed time: 115 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Please support explain the correct flash procedure to flash this phone, reapair the eeprom, and all rest, as soon as possible. Thanks. this is the link to 100% work eeprom file ![]() B5722_M-S_E2P.rar - 4shared.com - online file sharing and storage - download |
![]() | #3 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Mar 2012 Location: Worldwide
Member: 1737147 Status: Offline Thanks Meter: 555 | Thanks for your POst But Now you have Correct EEPRom so your problem is Solved.. or why you search 3 days. why you did not post here.. i want Better EEPRom File. if you will did post here so you can't waste your time 3 days. |
![]() | #4 (permalink) | |
Member: 1332352 Status: Offline Thanks Meter: 2 | Quote:
but now i don't understad how to repair EEPROM with the box and so i ask you: can you help me with eeprom repair? .. for the waste of time: i don't think that research or try some attempts is a waste of time, in contrary ! ![]() p.s. if you like my post, please click on thanks ![]() | |
![]() | #5 (permalink) |
Member: 1737147 Status: Offline Thanks Meter: 555 | Bro you said you search 3 days But in Forum already atested EEProm available. With Full Detail Already Available many Posts about B5722 EEProm. So plz first use the search button if you can't find any solution so POst here. Check these Links. Samsung E2P FULL Samsung b5722 e2p B5722 E2P eeprom needed ( master + slave ) B5722 stuck at startup screen Samsung B5722 showing as BD0204EE http://*******************.com/forum...ogo-fixed.html AND Many other Posts available Plz Don't Spam the Forum.. !!So Plz Next time CareFully!! |
The Following User Says Thank You to GsmNafees For This Useful Post: |
![]() | #6 (permalink) |
Member: 1332352 Status: Offline Thanks Meter: 2 | Thanks for suggestion, now i've understand how to search e2p file and sorry if the post seems a spam,... but i've asked how to repair EEPROM whit z3x box, becouse seems no way to do it !! Is this available in the forum (i've tried to search without result) ? |
![]() | #7 (permalink) | |
- rename the extension of files, from .BIN to .SW_EEP; - click WRITE in the EEPROM section and select renamed file; for ex. B5722_358576-03-xxxxxx-6_MASTER_E2P.bin become B5722_358576-03-xxxxxx-6_MASTER_E2P.sw_eep - after write, you have to repair IMEI ..waiting for repair solution from the supporters.. | |
![]() | #8 (permalink) | |
Member: 1737147 Status: Offline Thanks Meter: 555 | Quote:
open the Z3X Box Software Select model B5722_m LooK the right side table and click on Setting MOdel & select Flash Mode. ( i mean already mode is TAT Mode but know you change this on Flash Mode) Now back Click on JoB Write IMEI in the IMEI place and serial number in the serial number Place & click on Custom and wait for process DONE. when completed this So Now select the Model B5722_s & Do Same Process. i try this method 2 time on 2 Phones & this is Working.. if this Worked so Don't Forgot click on Thanks | |
The Following 2 Users Say Thank You to GsmNafees For This Useful Post: |
![]() | #9 (permalink) | |
Insane Poster ![]() ![]() ![]() Join Date: Jan 2012 Location: Barcelona Spain
Member: 1712183 Status: Offline Thanks Meter: 13 | Quote:
Just Open your Eyes and USE the SEarch Button or Google. | |
![]() | #10 (permalink) |
Member: 1332352 Status: Offline Thanks Meter: 2 | Dear all, thanks for your reply but problems still remain: as the log on the top of post, the box can't write the master imei number i've tried all variants of procedures (Opening my Eyes and USing the SEarch Button and Google) without result, and this is the reason of my post.. with others box, repair is possible, and my question is this: why not with z3x? |
![]() | #11 (permalink) |
Member: 1737147 Status: Offline Thanks Meter: 555 | Change the Speed & retry with same process Speed option available down the ComPOrt Option.. Try Diferent Speed & POst here Result. or if the problem not solved With diferent speed so contact with me.. i can solve your problem on remote server team viewer 7. [email protected] |
![]() | #13 (permalink) |
Member: 1332352 Status: Offline Thanks Meter: 2 | and so: change the speed, doesn't work becouse i've always the same message but, .. but the box don't say the truth !! In fact, even if wrong message, box repair the IMEI and S/N, and when i've repaired slave too,... VOILA', the phone come back to life!! Than, after a test, i can say that: - phone arrived as "hold when send sms, restart itself", firmware version 2010; - attempting to update, i've corrupt eeprom section, deleting partition too; - attempting to fix with "standard" eeprom file found on z3x support, i've got the error message blinking " bd0204ee "; - when find a 100% eeprom working file (see link on top), i've write this on the partitions (master, slave); - i've write this firmware B5722XXKI1_OXAKI1 (from z3x support) in both partition; - in the end, i've fix Imei and serial number in both partition - 100 % working !! Sayng THANKS to all user that friendly answered to this post, this is finally log: ------------------------------------------------------------------------------- Selected model: B5722_m Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Phone IMEI -> 00000000000000 Phone SW -> Langpack-> Not found langpack ! Phone HW -> Phone BT ADDR -> Phone WI-FI ADDR -> Read Info - ok Elapsed time: 97 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Selected model: B5722_m Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Write EEP - ok Elapsed time: 87 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Selected model: B5722_s Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Please,press power button on 3 seconds Slave Detected Sending slave loader1... OK Flash ID: 54 Sending slave loader2... OK Write EEP - ok Elapsed time: 66 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Selected model: B5722_m Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Start TFS format... OK Start NOR flash NOR flash - ok Start Flash TFS Mount TFS - ok Create DIR - ok TFS flash - ok Start Flash CSC CSC format - ok Mount CSC - ok Create DIR - ok CSC flash - ok Write signature - ok Download - ok Elapsed time: 1376 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Selected model: B5722_s Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Please,press power button on 3 seconds Slave Detected Sending slave loader1... OK Flash ID: 54 Sending slave loader2... OK Start NOR flash NOR flash - ok Start Flash TFS Download - ok Elapsed time: 304 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Selected model: B5722_m Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Repair IMEI block Repair IMEI block Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 131 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Selected model: B5722_s Selected com port: COM8 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3B11 Sending loader2... OK Flash ID: 00EC2206000100000034 Please,press power button on 3 seconds Slave Detected Sending slave loader1... OK Flash ID: 54 Sending slave loader2... OK Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 79 second, sw ver: 3.5.0035 ------------------------------------------------------------------------------- Have a fun, Bye |
![]() | #14 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 ![]() | Quote:
The Speed is OK, the More HIGH if use the C450 RJ45 Cable, if use J750 RJ45 Cable the Fw Writer is stopping, Good lucky to all, and Good Z3X finally all work very good....ahahah HOW FOREVERRRRRRRRR... Regards Max | |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
Eeprom dump lost, help needed. | CAMILO | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 18:04 |
5110&6110 Eeprom header... | O'Malley | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-15-2009 21:41 |
Upload / Download eeprom program for 51xx/61xx | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-07-1999 14:03 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
