06-28-2011, 13:20 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Age: 43
Member: 978268 Status: Offline Thanks Meter: 83 | Samsung c3222 cant unlock TEAM i got samsung c3222 for phone lock password ,when i connect it ,it says to press and hold vol down + lock button, i want to know which is the lock button ,whether it is (alt) with lock icon or there is a button on right hand side ,which one i have to press |
06-28-2011, 14:05 | #2 (permalink) |
Member: 978268 Status: Offline Thanks Meter: 83 | problem solved how 1. remove battery from phone 2. press and hold volume down and sim swaping button on the right top side of the phone 3. inset usb cable ,phones enter in DFU mode this is the log Selected model: C3222 Selected com port: COM4 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 131 second, sw ver: 3.5.0024 |
The Following User Says Thank You to rkinfo_khan For This Useful Post: |
09-04-2011, 08:58 | #4 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: Iran Age: 36
Member: 103435 Status: Offline Thanks Meter: 49 | Quote:
09-09-2011, 11:59 | #6 (permalink) |
Insane Poster Join Date: Jan 2010 Location: port blair Age: 43
Member: 1215464 Status: Offline Thanks Meter: 3 | press and hold volume down and sim swaping button on the right top side of the phone Selected model: C3222 Selected com port: COM17 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 167 second, sw ver: 3.5.0025 |
11-23-2011, 14:48 | #8 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: india Age: 44
Member: 1623262 Status: Offline Sonork: 100.1621312 Thanks Meter: 96 | Quote:
11-24-2011, 13:10 | #9 (permalink) |
Freak Poster Join Date: Dec 2007 Location: nowshera pakistan
Member: 651119 Status: Offline Sonork: 100.1603096 Thanks Meter: 48 | 1.remove batry first 2.use usb cable like 513. 3 chang the sitting n exe flash mode salect 4.press volum down+sim swiping putton n right side the phon then click unlock |
03-01-2012, 17:18 | #10 (permalink) |
Freak Poster Join Date: Jul 2007 Location: some where Age: 41
Member: 545608 Status: Offline Thanks Meter: 25 | use c3300k com cable Selected model: C3222 Selected com port: COM19 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3222XXKF1 Phone CSC: C3222OXFKF2 Phone BT ADDR: 9463-D1-C91971 Phone IMEI: 35529504614713 Deactivated MSL - TRUE Unlock - ok Elapsed time: 50 second, sw ver: 3.5.0033 |
04-09-2012, 12:27 | #11 (permalink) |
Junior Member Join Date: Apr 2012 Location: Mumbai
Member: 1744523 Status: Offline Thanks Meter: 4,294,967,295 | Selected model: C3222 Selected com port: COM20 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Unlock block Unlock block Unlock block Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 58 second, sw ver: 3.5.0034 |
06-19-2012, 18:37 | #12 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Romania Age: 41
Member: 1722871 Status: Offline Thanks Meter: 116 | I have discovered a beter way to unlock it. 1. Power off the phone 2. Press [Reade codes] 3. Hold Vol DOWN + Sim Change button and then connect C3300K cable z3x does the rest: Code: ------------------------------------------------------------------------------- Selected model: C3222 Selected com port: COM25 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3222XXKF1 Phone CSC: C3222OXFKF2 Phone BT ADDR: 0007-AB-359C01 Phone IMEI: 35529504664692 Deactivated MSL - TRUE [FREZEE]: 39611380 [NET Lock]: 19933190 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 84867194 [Phone Lock]: 00000000 Read info - ok Elapsed time: 41 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- |
06-20-2012, 13:04 | #13 (permalink) |
Insane Poster Join Date: Jun 2007 Location: portugal Age: 56
Member: 528246 Status: Offline Thanks Meter: 4 | Selected model: C3222 Selected com port: COM19 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Unlock block Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 107 second, sw ver: 3.5.003 ------------------------------ |
12-18-2012, 10:23 | #14 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 744022 Status: Offline Thanks Meter: 33 | try dis with rj45 Selected model: C3222 Selected com port: COM4 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3222DDJL3 Phone CSC: C3222ODDJL1 Phone BT ADDR: 3C5A-37-AA54F1 Phone IMEI: 35540904045886 Deactivated MSL - TRUE Unlock - ok Elapsed time: 141 second, sw ver: 3.5.0028 ------------------------------------------------------------------------------- |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
