08-21-2015, 10:29 | #1 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 826522 Status: Offline Thanks Meter: 33 | c3222 unlocking procedure 1- go settings model tab & select usb ,flash mode according to ur need but usb is must. 2-press volume - & right side upper key ( lock key )now press direct unlock tab and insert usb and u will get the result. Selected model: C3222 Selected com port: COM21 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 125 second, sw ver: 3.5.0040 |
