samsung c3222 flashing problem samsung c3222 flashing problem here is log Selected model: C3222 Selected com port: COM13 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 36 second, sw ver: 3.5.0009 its only user code i try to flash the handset but not connect and device manager show connect what to do |
buy a cable of MICRO UART CABLE FOR SAMSUNG. |
in this model not support uart cable only usb cable use in it |
For unlock & user code press direct unlock and make full reset !! |
WORKING GOOD FOR ME. MY PHONE IS USER CODE. BE CAREFULL OF PRESSING ONLY VOL DOWN+ALT(LOCK)KEY. NONE OTHER KEYS SHOULD BE PRESSED TOGETHER AND CONNECT USB. WORKS FINE Selected model: C3222 Selected com port: COM3 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone master IMEI -> 35426804126288 Phone slave IMEI -> 3******4126288 Phone SW -> C3222DDJJ9 Langpack-> India Phone HW -> MP 0.400 Phone BT ADDR -> 0012-47-000001 [FREEZE LOCK]: [NET LOCK]: [SIM LOCK]: [PHONE LOCK]: [SP LOCK]: Read Info - ok Elapsed time: 101 second, sw ver: 3.5.0021 Selected model: C3222 Selected com port: COM3 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Unlock block Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 164 second, sw ver: 3.5.0021 ------------------------------------------------------------------------------- 100% WORKS |
i have some problem, please help mr blang. trims.... |
same here, always fail with uart cable after about 50 sec and usb: vol down and lock does nothing :( |
i have the same problem.. What can i do to flash my samsung c3222?? Help! |
dear bro i have c3222 but its not connected when i press both volume down + lock key...its not connect with micro usb cable. kindly send me solution on my id [email protected] |
getting in dfu mode and disconnecting plz help boss......................... |
z3x box only use with usb........ Selected model: C3222 Selected com port: COM3 Selected speed port: 921600 Press "volume down" + "sim changer key" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Unlock block Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 164 second, sw ver: 3.5.0021 [email protected] Don't forget thanks key.......... |
i need samsung c3222 network perfect solution .........have anybody any solution? thanx in advance |
Any help for flashing c3222? :confused: Selected model: C3222 Selected com port: COM3 Selected speed port: 921600 Not support uart algo for this phone Download - ok Elapsed time: 2 second, sw ver: 3.5.0040 |
