05-14-2015, 06:30 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Shibgonj6340
Member: 844312 Status: Offline Sonork: 100.1640471 Thanks Meter: 257 | Samsung C3222 same e2p file hwk box Partition Table: C3222OPEN.ptt TFS File: C3222XXJJE.tfs CRC32: A058D08E CFG File: C3222XXJJE.cfg 92860 byte(s) CSC File: C3222OXEJJ8.csc CRC32: F5C24234 CCF File: C3222OXEJJ8.ccf 38684 byte(s) Connect Cable to Switched Off Mobile (with battery) Preloader Ok 08, 921600 Baud FLASH Id: SEC, K5N5629ATA [NOR 256Mb] + [NAND 1G] NAND Format Complete, Time: 00:05 Partition LCDACT: C3222OPEN.bootlcdact File CRC: 0x3A8850AC MCU Write Done, 3972 byte(s), Time: 00:00 Partition MAIN: C3222OPEN.cla\ER_FLASH_REGION2_CB File CRC: 0x7CA3CAC7 MCU Write Done, 27215268 byte(s), Time: 11:31 Partition DSP: C3222OPEN.cla\ER_FLASH_DSP_PATCH File CRC: 0x44FA5324 MCU Write Done, 489392 byte(s), Time: 00:14 Partition ROOT: C3222OPEN.cla\ER_FLASH_REGION1_CB File CRC: 0x58DE4B5D MCU Write Done, 50016 byte(s), Time: 00:02 BOOT: C3222OPEN.bootloader BOOT: Patched Ok File CRC: 0x707CAA55 BOOT Write Done, 48720 byte(s), Time: 00:02 File CRC: 0xA058D08E TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 133 Max_Files : 1151 Files_Count: 1151/1151 TFS Unmounted TFS Write Done, 23915635 byte(s), Time: 06:26 CSC Format Done, Time: 00:00 File CRC: 0xF5C24234 TFS Version: TFS4.0_CORONA_01 Directories: 48 Max_Files : 419 Files_Count: 419/419 CSC Unmounted CSC Write Done, 6958431 byte(s), Time: 02:05 Samsung neij backup efs |
05-14-2015, 07:11 | #2 (permalink) |
Member: 844312 Status: Offline Sonork: 100.1640471 Thanks Meter: 257 | Samsung C3222 Samsung C3222 Bloking Defence !! !! ERROR Code Already e2p file write good same case flashing any 32222 file same case need solution Simple File Sharing and Storage. Samsung C3222 Vedio |
