08-03-2013, 13:29 | #3 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1980581 Status: Offline Sonork: 100.1601250 Thanks Meter: 0 | Selected model: C3303 Selected com port: Selected speed port: 921600 Not support uart algo for this phone Download - ok Elapsed time: 2 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- plz help |
04-03-2014, 12:54 | #4 (permalink) |
Freak Poster Join Date: Jan 2013 Location: kathamandu nepal
Member: 1863514 Status: Offline Sonork: [email protected] Thanks Meter: 14 | SAMSUNG C3303I SUCCESSFULLY FLASHED BY Z3X 2013 1) SELECT C3303 MODEL 2) add the flash files 3) go to setting 4) tick flash mode and usb mode 5) click on firmware. 6) remove the battery from your mobile, 7) press volume down key + lock key 6) connect the usb cable without the battery THEN START FIREWARE INSERT BATTERY 100% OK |
04-06-2015, 09:03 | #5 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1543538 Status: Offline Sonork: 100.12345 Thanks Meter: 2 | SAMSUNG C3303I SUCCESSFULLY FLASHED BY Z3X 2013 1) SELECT C3303 MODEL 2) add the flash files 3) go to setting 4) tick flash mode and usb mode 5) click on firmware. 6) remove the battery from your mobile, 7) press volume down key + lock key 6) connect the usb cable without the battery THEN START FIREWARE INSERT BATTERY 100% OK..... ....youre correct mate ,thanx for detailed instruction.. |
