Old 04-10-2012, 12:16   #1 (permalink)
..::SH@RIF®™::..'s Avatar
Member: 929782
Sonork: 100.1641069
Thanks Meter: 617
Post Samsung C3310 successfully Unlock By z3x-Box
Unlock Procedure:
Phone First Need to full Flash High Version Then Click Direct Unlock & Enjoy
Flash log:
Unlock log:
Flash log:
Selected model: C3310
Selected com port: COM3
Selected speed port: 921600
Phone must be OFF
Press * and connect phone by USB cable
Connecting to Device... OK
Sending preloader ... OK
Sending loader ... OK
Erasing ... OK
Sending...C3310XXLA6_psi.fls (psi.fls)
Writing ... OK
Sending...C3310XXLA6_slb.fls (slb.fls)
Writing ... OK
Sending...C3310XXLA6_BSY.fls (CATFISH.fls)
Writing ... OK
Writing ... OK
Sending...C3310XXLA6_CDS.fls (CATFISH.fls)
Writing ... OK
Sending...C3310OXALA5_CSC.dffs (temp_GT-C3310_OXA.dffs)
Writing ... OK
Flash FLS - ok
Elapsed time: 149 second, sw ver: 3.5.0035
Unlock log:
Selected com port: COM9
Attention !!! Use this operation after flashing phone
Search diag port... OK (COM9)
Phone SN: RV1C23PA8M
Deactivate MSL - OK
Unlock - ok
Elapsed time: 23 second, sw ver: 3.5.0035
Br,
..::SH@RIF®™::..
The Following 5 Users Say Thank You to ..::SH@RIF®™::.. For This Useful Post:
Old 05-11-2012, 13:35   #2 (permalink)
Member: 116802
Thanks Meter: 3
Erasing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Flash FLS - ok
Elapsed time: 140 second, sw ver: 3.5.0035
Selected speed port: 115200
Search diag port... OK (COM3)
Phone SN: RV1C30A5V8
Deactivate MSL - OK
Unlock - ok
Elapsed time: 93 second, sw ver: 3.5.0035
Old 05-11-2012, 13:43   #3 (permalink)
Member: 116802
Thanks Meter: 3
some help
first Flash with micro usb
after u tick direct unlock
wen port found OK u see (COM3) then remove from usb
and put in UART RJ45 in z3x box and wait for unlock
if u have problem put speed to low
good luck ...
Old 05-15-2012, 07:20   #4 (permalink)
Member: 674296
Thanks Meter: 11
from where on keyboard or from phone
Old 05-16-2012, 11:41   #5 (permalink)
Member: 116802
Thanks Meter: 3
first flash phone no need to pres nothing install drivers
and the software will detect withot presing nothing .......
The Following User Says Thank You to shpetim For This Useful Post:
Old 05-22-2012, 15:25   #6 (permalink)
Member: 90859
Sonork: 100.1623226
Thanks Meter: 42
thanx
Phone must be OFF
Erasing ... OK
Sending...C3310XXLA4_psi.fls (psi.fls)
Writing ... OK
Sending...C3310XXLA4_slb.fls (slb.fls)
Writing ... OK
Sending...C3310XXLA4_BSY.fls (CATFISH.fls)
Writing ... OK
Writing ... OK
Sending...C3310XXLA4_CDS.fls (CATFISH.fls)
Writing ... OK
Sending...C3310OXELA2_CSC.dffs (temp_GT-C3310_OXE.dffs)
Writing ... OK
Flash FLS - ok
Elapsed time: 133 second, sw ver: 3.5.0036
Search diag port... OK (COM7)
Phone SN: RV1C302M0P
Deactivate MSL - OK
Unlock - ok
Elapsed time: 23 second, sw ver: 3.5.0036
The Following User Says Thank You to sahboub For This Useful Post:
Old 06-20-2012, 07:22   #7 (permalink)
Member: 127093
Thanks Meter: 22
Selected com port: COM88
Phone must be OFF
Erasing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Flash FLS - ok
Elapsed time: 168 second, sw ver: 3.5.0037
Search diag port... OK (COM88)
Phone SN: RV1C16RY49
Deactivate MSL - OK
Unlock - ok
Elapsed time: 55 second, sw ver: 3.5.0037
Old 07-19-2012, 18:35   #8 (permalink)
Albelektronik's Avatar
Member: 178513
Thanks Meter: 109
Hello, yes confirmed, who have problem to connect it or what cable to use do this:
Use usb microusb cable, phone without battery and disconected from cable....
press flash ( write firmware ) and then connect with microusb ( without battery ) , once detected will flash it and unlock ( if user code ) if operator lock do the same procedure, but click Unlock Botton
The Following User Says Thank You to Albelektronik For This Useful Post:
Old 07-24-2012, 21:24   #9 (permalink)
Member: 220595
Thanks Meter: 355
I spent some hours trying to unlock c3330 some days ago, and finally the customer took the phone.
now I have one c3310, and I was doing same mistake from c3330, I was connecting phone in Flash / download mode, pressing volume down + power button.
It is important to notice this, as albelektronic posted... I did it with the battery and worked
- select flash files and click Firmware
- after asked to do so, and haveng the phone powered off, Connect the usb cable and software will automatically start to flashing the phone.
- after finishing writing, do not disconnect the phone, phone will restart and computer will detect it,
- Click Direct unlock and will be unlocked..
Old 07-24-2012, 21:26   #10 (permalink)
Member: 220595
Thanks Meter: 355
The Following User Says Thank You to yurais For This Useful Post:
Old 08-16-2012, 10:54   #11 (permalink)
allal123's Avatar
Member: 192681
Sonork: 100.106870
Thanks Meter: 5,082
Flash with USB cable without battery + Unlock with USB cable with battery and phone powered ON .
--------------------------- 16/08/2012 10:48:21 -----------------------------
Phone must be OFF
Erasing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Flash FLS - ok
Elapsed time: 152 second, sw ver: 3.5.0038
Selected com port: COM30
Search diag port... OK (COM31)
Phone SN: RV1C16RYBM
Deactivate MSL - OK
Unlock - ok
Elapsed time: 23 second, sw ver: 3.5.0038
Phone must be OFF
Erasing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Flash FLS - ok
Elapsed time: 167 second, sw ver: 3.5.0038
Phone SN: RV1C16SHMA
Deactivate MSL - OK
Unlock - ok
Phone must be OFF
Erasing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Flash FLS - ok
Elapsed time: 151 second, sw ver: 3.5.0038
Phone SN: RV1C16RYLB
Deactivate MSL - OK
Unlock - ok
Phone must be OFF
Erasing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Flash FLS - ok
Elapsed time: 153 second, sw ver: 3.5.0038
Phone SN: RV1C16SHGA
Deactivate MSL - OK
Unlock - ok
The Following User Says Thank You to allal123 For This Useful Post:
Old 08-22-2012, 20:52   #12 (permalink)
abdaouicom's Avatar
Member: 236295
Thanks Meter: 38
Les amis,
Lorsque vous voulez débloquer le c3310 avec z3x il faut dans un premier temps flasher avec n'importe quelle version du support.
Lorsque z3x vous dit " appuyer sur la touche étoile " il faut en réalité appuyer sur la touche du milieu puis brancher le cable tout en maintenant la touche.
Le flash est rapide !
Ensuite durant le unlock aller dans gestionnaire de périphérique et désactiver le port Z3X puis "Read Info"
UNLOCK DONE !
The Following User Says Thank You to abdaouicom For This Useful Post:
Old 08-23-2012, 04:58   #13 (permalink)
Nishith's Avatar
Member: 1766148
Sonork: 100.1614494
Thanks Meter: 490
Originally Posted by abdaouicom View Post
Les amis,
UNLOCK DONE !
Nice Info..
But,
Use English Language so all users can Understand..!!!
Old 01-04-2013, 08:59   #14 (permalink)
..:ALAK:..'s Avatar
Member: 1813575
Thanks Meter: 90
Selected com port: COM26
Selected speed port: 460800
Phone must be OFF
Erasing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Writing ... OK
Flash FLS - ok
Elapsed time: 170 second, sw ver: 3.5.0037
Search diag port... OK (COM76)
Phone SN: RF1C94TLHB
Deactivate MSL - OK
Unlock - ok
Elapsed time: 48 second, sw ver: 3.5.0037
Old 01-04-2013, 09:07   #15 (permalink)
Cheater -Don't Deal with him-
Member: 1850093
Sonork: 100.1627469
Thanks Meter: 339
nice share Z3X BOSS TEAM
The Following User Says Thank You to gsmnsd For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
Page generated in 0.27115 seconds with 9 queries
