02-17-2014, 14:23 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Raiganj Age: 37
Member: 1175794 Status: Offline Thanks Meter: 186 | samsung c3312r dead after wrong flash.. help now the handset is totally dead , no more download mode is showing up. CAN ANYBODY GUIDE ME HOW TO REPAIR THE BOOT or ANY WAY TO ALIVE THE HANDSET. Last edited by n2roy; 02-17-2014 at 14:29. |
02-17-2014, 14:48 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | How To Update Samsung C3312 Champ Deluxe Duos Firmware By USB Cable Files and Programs: - Samsung C3312 Champ Deluxe Duos Firmware Package. - FlashTool Program. - USB Drivers for Samsung C3312. After downloading the above files, Extract the zipped ones, And install the USB drivers on your PC, Then restart it. Tools: - Origrinal USB cable of Samsung C3312, Or any suitable one. - A computer running Windows OS. Samsung C3312 Champ Deluxe Duos Firmware Update Steps: - Turn your Samsung C3312 off, And take out its battery, SIM cards, And memory card. - From the flasher folder run FlashTool_E2.exe - To Select the Firmware files from its extracted folder click on (...) button,You have to do so for each file. - The selecting of firmware files must be in the below order: - C3312xxxxx_psi.fls - C3312xxxxx_slb.fls - C3312xxxxx_BSY.fls - C3312xxxxx_CDS.fls - C3312Oxxxx_CSC.dffs - Now Check these settings: Custom Order (Must be checked). Erases Calibration! : Select (Erase whole flash before download). Baud Rate: 921600 Communication Driver: Infineon USB Driver. - Now you can click on Next button, And a new window will appear. - Click on Start USB1 button. - Now you have to connect your Samsung C3312 to PC using the USB cable. - There are more than one way to connect your phone, You can try any one of the following: 1- With the phone's battery in, Press Volume Down key then connect the USB cable to it. 2- With the phone's battery in, Press Home key then connect the USB cable to it. 3- Connect the USB cable to phone without battery, After it is detected you can insert the battery. - After the FlashTool starts the update process you have to wait for some minutes. - When the operation is done, You will see a Success word, And that means it was done right. - Disconnect the USB cable from phone. - With your Samsung C3312 Champ Deluxe Duos on, Do a full reset by this code *2767*3855# - Now when your phone restart it will be ready for using with its new firmware. Recommended Links: - Unlock Your Samsung C3312 Champ Deluxe Duos Online. |
02-17-2014, 15:32 | #4 (permalink) | |
Member: 1175794 Status: Offline Thanks Meter: 186 | @noure Quote:
dude i know how to flash a samsung with samsung flashtool_e2. but the problem was after wrong flash handset was not showing download mode.. after searching gsmhosting.com I found useful post, now my handset is alive again, TO THOSE WHO FACED SAME PRONBLEM AS ME, DO THIS TRICK WITH DEAD C3312R, FIRST SELECT ALL FILES(INCLUDE CSE) ON FLASHTOOL_E2, and click on start usb flashing... * NOW "WITHOUT BATTERY" PRESS AND HOLD VOL DOWN AND LOCK BUTTON AND INSERT USB CABLE... MIND IT THAT KEEP PRESSING VOL DOWN AND LOCK BUTTON UNTIL FLASHING IS COMPLETE . DONE YOUR HANDSET WILL ALIVE AGAIN. | |
09-20-2014, 10:13 | #5 (permalink) |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | samsung c3312r blinking solution 1000% if software damage try to flash with c3312r if done than nop if same blinking than first flash with c3312 file after done. u got phone now working good than u want to reflash with c3312r will be done your phone tested by me 100% workng solution C3312RJPMD2_OJPMD3 |
02-19-2015, 11:14 | #6 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Tiptur- Karnataka, india
Member: 1809212 Status: Offline Sonork: 1000.2 Thanks Meter: 79 | use hwk/ flash in usb mode 1000% done here is log Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2013 December Rev: 1 Insert USB Cable to Switched Off Phone IF_USB: XGOLDxxx IF_SBL: XGOLD215, Ok IF_EBL: 2150_OD_KJ2_3.1 3.1, Mode: BB FL_ID : EC003000, Samsung OneNAND-1G 1024+32Mb Erase Area: 0x00000000 - 0x0FFFFFFD, Erased: 00:00 C3312RDDML1_psi.fls FLASH BUNDLE: Flash File: psi.fls Write Area: 0x00090000 - 0x000AF87E, Written: 00:00 C3312RDDML1_slb.fls FLASH BUNDLE: Flash File: slb.fls Write Area: 0x60000000 - 0x60048A46, Written: 00:00 C3312RDDML1_CDS.fls FLASH BUNDLE: Flash File: CATFISH.fls Write Area: 0x63F60000 - 0x63FB848A, Written: 00:00 C3312RODDML1_CSC.dffs FLASH BUNDLE: Flash File: temp_GT-C3312_ODD.dffs Write Area: 0x44160000 - 0x470F60EE, Written: 01:10 MSL Patched OK: 00:00 C3312RDDML1_BSY.fls FLASH BUNDLE: Flash File: CATFISH.fls Write Area: 0x63200000 - 0x6386BE42, Written: 00:07 Write Area: 0x66000000 - 0x67DFCC16, Written: 00:35 ShutDown Done All Done, Time: 02:17 Make [Reset MMI] or Use *2767*3855# at First Start ! |
