09-04-2011, 10:53 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india Age: 43
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | samsung c3500 unlocking probleam logs : > Code: Selected model: C3500 Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3500XXKB2 Phone CSC: C3500OXAKB1 Phone BT ADDR: 2013-E0-7F018E Phone IMEI: 354028######## Deactivated MSL - FAIL Elapsed time: 121 second, sw ver: 3.5.0026 logs :> Code: Selected model: C3500 Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3500XXKB2 Phone CSC: C3500OXAKB1 Phone BT ADDR: 2013-E0-7F018E Phone IMEI: 354028######## Deactivated MSL - FAIL Elapsed time: 138 second, sw ver: 3.5.0026 |
09-05-2011, 08:08 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Baltchik,Bulgaria Age: 50
Member: 47236 Status: Online Thanks Meter: 58 | same situation with new exe Code: Selected model: C3500 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3500XXKA3 Phone CSC: C3500OXFKA2 Phone BT ADDR: 8C71-F8-7258BB Phone IMEI: 35402804xxxxxxx Deactivated MSL - FAIL Elapsed time: 147 second, sw ver: 3.5.0027 ------------------------------------------------------------------------------- Code: Selected model: C3500 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3500XXKA3 Phone CSC: C3500OXFKA2 Phone BT ADDR: 8C71-F8-7258BB Phone IMEI: 35402xxxxxxxxxx Deactivated MSL - FAIL Elapsed time: 124 second, sw ver: 3.5.0027 |
09-05-2011, 08:20 | #4 (permalink) |
Member: 47236 Status: Online Thanks Meter: 58 | First of all here is Z3x donlge section, so if i need other dongle i will ask somewhere in the net so i unlocked phone easy via usb connection Code: Selected model: C3500 Selected com port: COM3 Selected speed port: 921600 Press "volume up" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 34 second, sw ver: 3.5.0027 ------------------------------------------------------------------------------- Selected model: C3500 Selected com port: COM3 Selected speed port: 921600 Press "volume up" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone master IMEI -> 3540280xxxxxxx Phone SW -> C3500XXKA3 Langpack-> Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom Phone HW -> MP 0.600 Phone BT ADDR -> 8C71-F8-7258BB [FREEZE LOCK]:20067010, [NET LOCK]:45507270, [SIM LOCK]:00000000, [PHONE LOCK]:00000000, [SP LOCK]:00000000, Read Info - ok Elapsed time: 79 second, sw ver: 3.5.0027 |
The Following User Says Thank You to vascof1 For This Useful Post: |
10-11-2011, 15:26 | #5 (permalink) |
Freak Poster Join Date: Jul 2005 Age: 47
Member: 161417 Status: Offline Thanks Meter: 19 | Selected model: C3500 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3500XXKB2 Phone CSC: C3500KPPKB1 Phone BT ADDR: 0418-0F-A959FF Phone IMEI: 35402804078035 Deactivated MSL - FAIL Elapsed time: 138 second, sw ver: 3.5.0028 Still not working Selected model: C3500 Selected com port: COM3 Selected speed port: 921600 Press "volume up" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone master IMEI -> 35402804078035 Phone SW -> C3500XXKB2 Langpack-> Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom Phone HW -> MP 0.600 Phone BT ADDR -> 0418-0F-A959FF Read Info - ok Elapsed time: 113 second, sw ver: 3.5.0028 still no code no unlock.. Please fix problem |
10-13-2011, 18:58 | #9 (permalink) |
Member: 161417 Status: Offline Thanks Meter: 19 | thanks for the support guy's but I have already tried many of similar models like c3300k and 3303 3300 and 3300i but just for the sake of it i tried your suggetions. c3300k with uart and usb cables here are the logs.. Selected model: C3300K Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: C3500XXKB2 Phone CSC: C3500KPPKB1 Phone BT ADDR: 0418-0F-A959FF Phone IMEI: 35402804078035 Deactivated MSL - FAIL Elapsed time: 19 second, sw ver: 3.5.0028 --------------------------------------------------------------------------- Selected model: C3300K Selected com port: COM3 Selected speed port: 921600 Press "volume up" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone master IMEI -> 35402804078035 Phone SW -> C3500XXKB2 Langpack-> Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom Phone HW -> MP 0.600 Phone BT ADDR -> 0418-0F-A959FF Read Info - ok Elapsed time: 87 second, sw ver: 3.5.0028 --------------------------------------------------------------------------- |
The Following User Says Thank You to Sengoku For This Useful Post: |
10-14-2011, 10:35 | #11 (permalink) |
Member: 161417 Status: Offline Thanks Meter: 19 | Where can i find a good eprom?? writing a eprom is a risky proposition. Have you tested it?? it could damage phone permanently. Z3X advertise they can unlock the phone so there should be no need to write eprom. i'm considering flashing the phone but only if some one can confirm this solves the issue.. |
10-14-2011, 11:17 | #12 (permalink) | |
Freak Poster Join Date: Jan 2010
Member: 1219062 Status: Offline Thanks Meter: 9 | Quote:
10-14-2011, 11:55 | #13 (permalink) |
Member: 161417 Status: Offline Thanks Meter: 19 | 1. press read code in Z3X. 2. when it asks you to connect phone, make sure it's turn off pull out battery and reinsert then while holding volume up + block key insert the usb cable. it should now find your phone. if not retry from step 2. sometimes you need to try a few times for it to connect properly.. good luck |
11-11-2011, 12:16 | #14 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | problem to unlock c3500 tried with different versions , also with latest ..; but samr cant read the codes it is phone freeze Selected model: C3500 Selected com port: COM18 Selected speed port: 921600 Press "volume up" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A33 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone master IMEI -> 35402804065576 Phone SW -> C3500MUKB1 Langpack-> Not found langpack ! Phone HW -> MP 0.600 Phone BT ADDR -> 0418-0F-671398 Read Info - ok Elapsed time: 24 second, sw ver: 3.5.0027 and with 0029 same result no luck !!!! |
12-15-2011, 03:47 | #15 (permalink) |
Major Poster Join Date: Nov 2010 Location: brasil rj
Member: 1450803 Status: Offline Thanks Meter: 2 | "volume up" + "lock" and connect USB cable to phone , observ drive usb dfu2 , unlock and repair imei 1000% , |
The Following User Says Thank You to raphael.aranha For This Useful Post: |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
