Old 09-04-2011, 10:53   #1 (permalink)
royal_electronics's Avatar
Member: 397892
Sonork: 100.1609899
Thanks Meter: 190
Arrow samsung c3500 unlocking probleam
helloo support team , samsung c3500 problem in unlocking . plz help . its urgent. when i try to read info than its show this error......
logs : >
Selected model: C3500
Selected com port: COM6
Selected speed port: 921600
Please, connect phone and press power button 3 seconds
Phone Detected
Use automatic parameters
Phone in TAT MODE
Phone SW: C3500XXKB2
Phone CSC: C3500OXAKB1
Phone BT ADDR: 2013-E0-7F018E
Phone  IMEI: 354028########
Deactivated MSL - FAIL
Elapsed time: 121 second, sw ver: 3.5.0026
if i try to direct unlocking than again its show : >
logs :>
Phone Detected
Phone in TAT MODE
Elapsed time: 138 second, sw ver: 3.5.0026
Old 09-05-2011, 08:08   #2 (permalink)
Member: 47236
Thanks Meter: 58
same situation with new exe
Selected com port: COM3
Phone Detected
Phone in TAT MODE
Phone SW: C3500XXKA3
Phone CSC: C3500OXFKA2
Phone BT ADDR: 8C71-F8-7258BB
Phone  IMEI: 35402804xxxxxxx
Elapsed time: 147 second, sw ver: 3.5.0027
Phone Detected
Phone in TAT MODE
Phone  IMEI: 35402xxxxxxxxxx
Elapsed time: 124 second, sw ver: 3.5.0027
Old 09-05-2011, 08:14   #3 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
chek other dongal br,,,,,,,
Old 09-05-2011, 08:20   #4 (permalink)
Member: 47236
Thanks Meter: 58
First of all here is Z3x donlge section, so if i need other dongle i will ask somewhere in the net
so i unlocked phone easy via usb connection
Press "volume up" + "lock" and connect USB cable to phone
Connect to control pipe... FAIL
Send loaders - fail
Elapsed time: 34 second, sw ver: 3.5.0027
Connect to control pipe... OK
Processor ID -> 0A33
Sending loader... OK
Connect to write pipe... OK
Connect to read pipe... OK
Damping... OK
Phone master IMEI -> 3540280xxxxxxx
Phone SW -> C3500XXKA3
Langpack-> Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom
Phone HW -> MP 0.600
Phone BT ADDR -> 8C71-F8-7258BB
[FREEZE LOCK]:20067010,
[NET LOCK]:45507270,
[SIM LOCK]:00000000,
[PHONE LOCK]:00000000,
[SP LOCK]:00000000,
Read Info - ok
Elapsed time: 79 second, sw ver: 3.5.0027
br to all
The Following User Says Thank You to vascof1 For This Useful Post:
Old 10-11-2011, 15:26   #5 (permalink)
Sengoku's Avatar
Member: 161417
Thanks Meter: 19
Phone Detected
Phone in TAT MODE
Phone CSC: C3500KPPKB1
Phone BT ADDR: 0418-0F-A959FF
Phone IMEI: 35402804078035
Elapsed time: 138 second, sw ver: 3.5.0028
Still not working
Damping... OK
Phone master IMEI -> 35402804078035
Phone SW -> C3500XXKB2
Phone BT ADDR -> 0418-0F-A959FF
Read Info - ok
Elapsed time: 113 second, sw ver: 3.5.0028
still no code no unlock..
Please fix problem
Old 10-11-2011, 15:27   #6 (permalink)
Sengoku's Avatar
Member: 161417
Thanks Meter: 19
double post
Old 10-13-2011, 02:05   #7 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
use model c3300k and try again post result
Old 10-13-2011, 06:03   #8 (permalink)
Cheater -Don't Deal with him-
Member: 1671843
Sonork: 100.1608405
Thanks Meter: 4
Yes Use The Usb Cable Your Problem 100% Solved Bro
Old 10-13-2011, 18:58   #9 (permalink)
Sengoku's Avatar
Member: 161417
Thanks Meter: 19
thanks for the support guy's but I have already tried many of similar
models like c3300k and 3303 3300 and 3300i
but just for the sake of it i tried your suggetions.
c3300k with uart and usb cables here are the logs..
Selected model: C3300K
Phone Detected
Phone in TAT MODE
Elapsed time: 19 second, sw ver: 3.5.0028
Damping... OK
Read Info - ok
Elapsed time: 87 second, sw ver: 3.5.0028
The Following User Says Thank You to Sengoku For This Useful Post:
Old 10-13-2011, 21:43   #10 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
write good eprom and unlock again restore imei original
Old 10-14-2011, 10:35   #11 (permalink)
Sengoku's Avatar
Member: 161417
Thanks Meter: 19
Where can i find a good eprom?? writing a eprom is a risky proposition.
Have you tested it?? it could damage phone permanently.
Z3X advertise they can unlock the phone so there should be no need to write eprom.
i'm considering flashing the phone but only if some one can confirm this solves the issue..
Old 10-14-2011, 11:17   #12 (permalink)
Member: 1219062
Thanks Meter: 9
Send loaders - fail
Damping... OK
[SP LOCK]:00000000,
Read Info - ok
br to all
HOW CAN you connect by USB,when I try to connect with USB phone just turn on(I press "volume up" + "lock") please help
Old 10-14-2011, 11:55   #13 (permalink)
Sengoku's Avatar
Member: 161417
Thanks Meter: 19
1. press read code in Z3X.
2. when it asks you to connect phone, make sure it's turn off pull out battery and reinsert
then while holding volume up + block key insert the usb cable.
it should now find your phone.
if not retry from step 2.
sometimes you need to try a few times for it to connect properly..
good luck
Old 11-11-2011, 12:16   #14 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
problem to unlock c3500
tried with different versions , also with latest ..; but samr cant read the codes
it is phone freeze
Selected com port: COM18
Damping... OK
Phone master IMEI -> 35402804065576
Phone SW -> C3500MUKB1
Langpack-> Not found langpack !
Phone BT ADDR -> 0418-0F-671398
Read Info - ok
Elapsed time: 24 second, sw ver: 3.5.0027
and with 0029 same result no luck !!!!
Old 12-15-2011, 03:47   #15 (permalink)
Member: 1450803
Thanks Meter: 2
"volume up" + "lock" and connect USB cable to phone , observ drive usb dfu2 , unlock and repair imei 1000% ,
The Following User Says Thank You to raphael.aranha For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.24326 seconds with 10 queries
