Samsung C3520 Success Fully Unlock " Phone LOCK " Samsung C3520 Success Fully Unlock " Phone LOCK " Using Cable : Micro -URT (C3300k) Select Other Settings ' TAT MODE ' Then Click to Read Info [Codes] Then connect phone and press power button 3 seconds http://img528.imageshack.us/img528/8...20coderead.png ...::: THANKS FOR Z3X TEAM :::... |
Would you be so kind an post screenshot of port 15 advanced settings under device manager (latency, timeouts, usb transfer sizes, miscllenaous options checkboxes) I do have some weird problem that I never in a 2 years could made an uart part working for unlock... Kind regards Haltec 4096, 4096, 1, 0, 0 and serialenumerator chacked. On 3.5.0022 gui TAT mode ON, and USE usb OFF And on .38 ver same And off course its same for 130k 150k 530k or 560k !!! with or without vcc connected Also same trough Cyclone box via uart stack emulator!!!! |
Thanks For Success Report....... BR. Arsalan gsm2000. |
Selected model: C3520 Selected com port: COM2 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Timeout Phone fail TAT MODE Read info - FAIL Elapsed time: 35 second, sw ver: 3.5.0040 BR Haltec |
Selected model: C3520 Selected com port: COM15 Selected speed port: 921600 Press "1" + "3" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A35 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Detected 12 partition Erasing... OK Erasing... OK Erasing... OK Erasing... OK Erasing... OK Erasing... OK Erasing... OK Erasing... OK Erasing... OK Erasing... OK Erasing... OK Start Flash phone Sending part IMAGE... OK Sending part LCDACT... OK Sending part DATA_RW... OK Sending part DSP... OK Sending part PAGE... OK Sending part MAIN... OK Sending part ROOT... OK Sending part a... OK Sending part b... OK Sending part c... OK Sending part d... OK Critical partition->12 - not flashed Sending boot... Erasing... OK Sending... OK Download - ok Elapsed time: 101 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3520 Selected com port: COM15 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Timeout Phone fail TAT MODE Read info - FAIL Elapsed time: 33 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3520 Selected com port: COM15 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Timeout Phone fail TAT MODE Read info - FAIL Elapsed time: 34 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3520 Selected com port: COM15 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Timeout Phone fail TAT MODE Read info - FAIL Elapsed time: 34 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3520 Selected com port: COM15 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Timeout Phone fail TAT MODE Read info - FAIL Elapsed time: 31 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- Selected model: C3520 Selected com port: COM15 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Timeout Phone fail TAT MODE Read info - FAIL Elapsed time: 35 second, sw ver: 3.5.0040 Any ideas ? BR Haltec Ah Yes - Completely different PC and OS WIn7 this time.... |
And by flashing differnt .ptt 7kb file, than your original one, you WILL get DIFFERENT languages in phone, whome is btw. NOT supported for fw upgrade via Kies. (C3520 phone itself) Haltec |
ikut sruput mas boz thanks cendolnya |
wow tnx for this man .. this can help newbies like me |
Today I have one C3520, but can not unlock like this. No need to make flash before unlock, just: 1. make full reset *2767*3855# 2. Click Read codes 3. Connect cable to phone (C3300K) 4. Connect battery 5. Hold down power button If you put battery, then cable, and the push power, will not go in TAT mode. :p Code: Selected model: C3520 |
yess, thanks z3x that i had tried n succes to unlock c3520 |
try my trick. just make a emergency call and insert code: *2767*2878# and without lost data... |
thanks working great for my problem ;) |
I also had the problem connecting C3520.... and correct way was is like it writes in first post but No need to make flash or full reset before unlock 2. Click Read codes 3. Connect cable to phone (C3300K) 4. Connect battery ...so just connect cable, press read codes and as soon as you get message to power on the phone insert battery, do not press power, phone sould power on by itself, and every time enter TAT mode, just tested on 10 pcs! If it doesn't want to enter TAT mode restart computer and reconnect box!! BR |
