10-18-2012, 12:40 | #3 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | TRY. 1. On phone keypad, enter this code: *#197328640# 2. press "6" (for Video) 3. press "3" (for Camera firmware) 4. press "1" (for CAM FW Ver Check, that is, Camera Firmware Version Check) (This is to check your current camera firmware version. You will see something like this: [1]SESBDG01:SESBDG01:SESBDG01] Note: The 1st of the three versions above is the current version available(from Samsung); the last 2 are the versions of camera firmware (photo and video) that you have on your phone. If all the three are of the same version, it means you already have the latest firmware and no need to upgrade. If the last or penultimate version is lesser than the first, then you need to upgrade your firmware. Continue as follows: 5. press "2" (for Phone to CAM FW Write) Note: The process of Camera Firmware Write takes approx four minutes. DO NOTHING!! JUST WAIT!! TILL PROCESS COMPLETES!!. You can brick your camera if you interrupt the camera upgrade process. That's All. Enjoy. |
The Following 3 Users Say Thank You to .::EXTREME::. For This Useful Post: |
10-18-2012, 13:25 | #5 (permalink) |
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Thanks For Report. This Error can solved with a flashing, with working firmware! its only camera file mismatch. Do reset after flashing! |
10-19-2012, 14:49 | #8 (permalink) |
No Life Poster Join Date: Apr 2011
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | i try these three versions S8530PMKA1_PRTKA1 S8530PMJL1_PRTJL2 S8530PMKE2_PRT but same error after installing camera firmware during installation of camera firmware says fail and now i start camera it says camera fail |
10-20-2012, 05:45 | #9 (permalink) |
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Last edited by .::EXTREME::.; 10-20-2012 at 05:51. |
The Following User Says Thank You to .::EXTREME::. For This Useful Post: |
10-20-2012, 06:52 | #10 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | look dear brother problem 100%software but this wave phones downgrade not possible with any tools you can use jtag erase full flash memory then flash 1.2 firmware after flash phone is alive but imei not active(means imei null) you can rebuild imei via z3x (z3x need to write patch file)patch file avilable on z3x support area then unlock and reset phone listen after flash cant updates camera firmware cuz after cam firmware updates again to killed cam |
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
10-20-2012, 08:04 | #11 (permalink) | |
Member: 1552610 Status: Offline Sonork: 100.1604734 Thanks Meter: 1,370 | Quote:
hi bro i try many files to flash but error and i try at last this version of 1.2 GT-S8530 2011 January Bada 1.2 S8530PMKA1 ## and set downgraded but the problem is same with camera | |
10-20-2012, 12:56 | #12 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Bro first you can use ort jtag then full erase flash memory after erase flash with z3x.after the flashing you can rebuild imei then check camera.after the flash cant run camera updating option cuz cam update killed phone cam without erase cant solved your problem i also faced this same problems i try this methode my problem 100%solved post result |
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
