08-28-2011, 07:53 | #1 (permalink) |
Major Poster Join Date: Apr 2011 Location: Indonesia
Member: 1551582 Status: Offline Thanks Meter: 3 | Samsung Corby B3310 i was remove plugin but proble still same...... i hope somebody give solution......thx |
08-28-2011, 08:46 | #5 (permalink) |
Member: 1551582 Status: Offline Thanks Meter: 3 | Region: 1, 0x20000000-0x20000063, Length: 100 bytes Region: 2, 0x2000C000-0x20011457, Length: 21592 bytes Region: 3, 0x20016000-0x2001C59B, Length: 26012 bytes Region: 4, 0x2001E000-0x2001E0B3, Length: 180 bytes Region: 5, 0x2003803C-0x20056933, Length: 125176 bytes Region: 6, 0x20058000-0x20058037, Length: 56 bytes Region: 7, 0x20058138-0x2005CF3D, Length: 19974 bytes Region: 8, 0x20078000-0x2018D30F, Length: 1135376 bytes Region: 9, 0x20300000-0x22165ED7, Length: 31874776 bytes USB Boot Ok, McuId: 00050015, Ubl: 0ED18B80, 7-1.1 (Vision X115E) Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_usb_s06_t.sre Flash1: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Flash2: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 MCU File: CODE_B3310DXJA1.s3 Flashing NOR part... Write Done, 33203322 byte(s), Time: 03:30 CTS File: CSC_B3310OLAIL6.csc FS Mounted (FDI) Files Count: 117 FS Unmounted FS Write Done, 10573906 byte(s), Time: 01:20 S/N : RQOZ331807 USB Closed, Reconnect Cable and Repower Phone for Next Operation |
12-09-2011, 15:04 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Quote: Originally Posted by tsarkh Run Samsung B3310 Downloader. Select Customer T: Nox (Intel Sibley 1024/256, USB). In Flash Option section check: Code Binary and CSC Binary(Default). Also check this Option: Erase all Unused Regions. Connect the phone in Download mode: Press * and connect USB cable to phone. Now select the Com Port that the phone takes. Select the S3 Flash file and CSC file too, each in his field. Click on Flash button and type YES in the message box then click OK to Start the process. Do not touch or remove the cable till the Program tell you: All is Well. Turn On the phone and do full reset by the code: *2767*3855#. For More Guide Check Here Good Flashing For All B3310 Firmware http://rapidshare.com/files/34135611...B3310XXIH2.zip I got many pieces solved on logo by this.You must have exact flash version. |
lots of service manuals Nokia, Siemens Sony Samsung etc. | -=KnOeFz=- | GSM Mobile Links | 4 | 11-16-2011 08:42 |
Samsung service soft. | fido | Samsung Flashers, Software, Firmware. | 4 | 01-20-2011 08:17 |
I need pinout for samsung a100 | laiyc | x1x to x45/x50 | 1 | 03-31-2001 23:47 |
Samsung SGH-200 (Help me -I need eeprom.) | jonwillow | Old Ericsson Phones & Sony Phones | 0 | 06-23-2000 09:38 |
I Trade software for Samsung | hercules | Old Ericsson Phones & Sony Phones | 0 | 05-27-1999 14:14 |
