Old 11-05-2015, 10:17   #61 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Selected model: E1200I
Selected port: COM10 Z3X BOX Serial Port
Selected port speed: 921600
Waiting phone... detected COM92
Sending FDL... OK
Reconnecting phone... OK
Reading NV... OK
Checking NV... OK
IMEI Master: 3582730644xxxxx
Phone HW: MP 0.400
Product code: GT2E1200ZKIORL
Please wait, calculating codes... OK (time - 00:00:50)
Freeze code:  40737246
NET lock:  79305096
Sub lock:  00000000
SP lock:  00000000
CP lock:  00000000
SIM lock:  00000000
For check lock status: *#7465625#
Old 11-17-2015, 12:21   #62 (permalink)
Member: 2485990
How can I install drivers for E1200i
When ever i connect my phone in flash mode
its says unidentified device
tried to update driver is well in device manager but no driver found
Thank you
BTw i am using z3x pro 23.3
Old 12-24-2015, 15:41   #63 (permalink)
AFZALHASMI's Avatar
Member: 304342
Thanks Meter: 20
flash the phone usb cable done tested Selected model: E1200I
Selected port: COM3 Z3X BOX Serial Port
Waiting phone... detected COM47
Sending FDL... OK
Reading NV... OK
Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Backup\nvitem_E1200I _24-12-2015_20-0-4.bin
Sending SSBOOT... OK
Sending PS... OK
Sending CSC... OK
Erasing FLASH... OK
Flashing done (time - 00:00:49)
Done with Samsung Tool v.19.1
Old 02-05-2016, 17:01   #64 (permalink)
Member: 1966461
Thanks Meter: 7
samsung e1200r not working
Waiting phone... not found
Done with Samsung Tool v.20.5
Old 02-05-2016, 17:03   #65 (permalink)
Member: 1966461
Thanks Meter: 7
Old 03-10-2016, 16:30   #66 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 622
after unlock restar my set
Selected model: E1200Y
Selected port: COM28 USB Serial Port
Waiting phone... detected COM82
Sending FDL... OK
Reading NV... OK
Checking NV... OK
IMEI Master: 351898062593951
Phone HW: MP 0.300
Product code:
Sending NV... OK
Unlock done
Searching Samsung modem... not found
Sending FDL... OK
Reading NV... OK
Checking NV... OK
Phone HW: MP 0.300
Product code:
Sending NV... OK
Unlock done
Sending FDL... OK
Reading NV... OK
Saved to C:\Program Files\Z3X\Samsung\SamsungToolPRO\Backup\nvitem_E12 00Y_10-3-2016_7-20-45.bin
Sending PS... OK
Sending CSC... OK
Erasing FLASH... OK
Flashing done (time - 00:01:40)
Old 03-31-2016, 21:48   #67 (permalink)
Member: 2053335
Thanks Meter: 6
Steps to Unlock Samsung E1200i
1. Open Samsung 18.9 version of Z3x
2. Use Cable E210+USB USB Cable to PC without connecting to the phone. Always connect directly to the PC not Z3X box.
3. Select Flash Mode and Port Z3X COM
4. Click the Read Code button and when Z3X program says Waiting Phone then hold the OK button on the phone and then connect the phone to the E210 cable. Do not release the OK button untill the PC detects the phone. Make sure NO battery is in the phone.
5. Windows will install the drivers and if the Z3X timeout by that time, let the drivers to install and then close Z3X application and then restart.
6. Follow the same process by pressing the OK button and then connect the E210 cable to phone. This process make take several attempts before the phone is detected.
7. Once detected it will give the unlock code.
8. Enjoy Z3X unlocking.
The Following User Says Thank You to alamj2000 For This Useful Post:
Old 05-10-2016, 14:55   #68 (permalink)
Member: 1579259
Thanks Meter: 3
Thumbs up e1200i successfully unlocked with z3x
Waiting phone... detected COM131
Sending FDL... OK
Reading NV... OK
Checking NV... OK
IMEI Master: 35xxxxxxxxxxxxxxxxx
Phone HW: MP 0.300
Product code: GT-E1200ZKIVOP
Phone S/N: R21F85L5W2
Sending NV... OK
Unlock done
Done with Samsung Tool PRO v.25.3
Old 06-02-2016, 18:10   #69 (permalink)
Member: 1312432
Sonork: killcrc
Thanks Meter: 3
Operation: Unlock
Selected model: GT-E1200I
Selected port: COM147 SPRD U2S Diag
Software version: 25.5
Reading phone info... OK
IMEI Master: 353736060134758
Product code: GT-E1200ZWITCL
Phone HW: MP 0.300
Phone S/N: R21F4033Z2
Unlocking... OK
Done with Samsung Tool PRO v.25.5
normal mode check
Old 08-21-2016, 16:06   #70 (permalink)
Member: 1010509
wow Nice Post its 1000% ok Thanks to all of u ....
Old 09-14-2016, 22:44   #71 (permalink)
Member: 999187
modelo seleccionado: E1200I
Puerto Seleccionado: COM303 SPRD U2S Diag
Velocidad del puerto seleccionada: 921600
Esperando telefono... detectado COM303
Envío de FDL... Listo
Volver a conectar el teléfono... Listo
Lectura NV... Listo
Comprobación NV... Listo
IMEI Maestro: 356893067505931
Teléfono HW: MP 0.400
Código del Producto: GT-E1200ZWIPHE
Envío NV... Listo
Desbloqueo Listo
Hecho con Samsung Tool v.19.0
Selected port: COM303 SPRD U2S Diag
Waiting phone... detected COM303
Sending FDL... OK
Reading NV... OK
Checking NV... OK
IMEI Master: 356893067505931
Phone HW: MP 0.400
Product code: GT-E1200ZWIPHE
Sending NV... OK
Unlock done
Done with Samsung Tool v.19.0
Old 11-18-2016, 10:38   #72 (permalink)
Member: 2574454
Sonork: akantechsonork.com
Plz help me to unlock/mode:GT-E1200,S/N:R21F300VWOk,imei-352174065775048.
Old 11-20-2016, 01:14   #73 (permalink)
Member: 1974488
Thanks Meter: 5
Do you have z3x box ? If yes it is too easy
Old 11-20-2016, 01:15   #74 (permalink)
Member: 1974488
Thanks Meter: 5
Old 10-03-2017, 16:44   #75 (permalink)
Member: 2599500
i need driverr please help me i have gt-e1200m
Page generated in 0.34324 seconds with 8 queries
