07-18-2014, 13:46 | #17 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1226010 Status: Offline Thanks Meter: 1 | Umbabaraumba you cant unlock it because of the samsung tool verison that you are using. I have the same problem like you and i was using v 17.7 then i download v 17.0 and the problem was solved! Selected model: E1200I Selected port: COM3 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM19 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Checking NV... OK IMEI Master: 35************* Phone HW: MP 0.300 Product code: GT-E1200ZKIMTL Sending NV... OK Unlock done Done with Samsung Tool v.17.0 |
04-28-2015, 15:58 | #20 (permalink) |
Freak Poster Join Date: Sep 2000 Age: 57
Member: 2200 Status: Offline Thanks Meter: 44 | here is solution here is full network change language and phone have full network https://www.youtube.com/watch?v=zxXAbwLGQgE |
05-23-2015, 08:02 | #21 (permalink) |
Freak Poster Join Date: Jun 2011 Location: ludhiana
Member: 1594080 Status: Offline Sonork: 100.1000 Thanks Meter: 32 | samsung e1200i sim lock done with z3x samsung e1200i sim lock done with z3x successfuly 1 first select flash mode from unlock option 2 click read codes 3 press center key then connect usb cable witout battry 4 enter freeze code in the phone 5 enjoy [/IMG] |
05-23-2015, 10:10 | #22 (permalink) | |
Major Poster Join Date: Jan 2015
Member: 2328822 Status: Offline Sonork: 1667389 Thanks Meter: 4 | Quote:
bro i was have the same error but i fix it by choose the model E1202Y and hit unlock good luck | |
12-24-2015, 15:47 | #24 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 304342 Status: Offline Thanks Meter: 20 | flash this file E1200IXXMH1 done tested Selected model: E1200I Selected port: COM3 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM47 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Backup\nvitem_E1200I _24-12-2015_20-0-4.bin Sending SSBOOT... OK Sending PS... OK Sending CSC... OK Erasing FLASH... OK Flashing done (time - 00:00:49) Done with Samsung Tool v.19.1 Done with Samsung Tool v.19.1 |
02-07-2017, 15:17 | #25 (permalink) |
Freak Poster Join Date: Mar 2006 Location: NIGERIA
Member: 246376 Status: Offline Thanks Meter: 11 | always read code. if direct unlock phone dead, download file from support about 3mb, if no network after flash write backed up nv by box during initial unlock, phone should come with full network. 100% tested solution. |
The Following User Says Thank You to yink link For This Useful Post: |
