11-13-2014, 16:56 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Athens
Member: 1020935 Status: Offline Sonork: 100.1604039 Thanks Meter: 28 | Samsung E1205y Dead Samsung E1205Y Dead After Flashing With Z3X Need Help or file to flash with Other Tool -------------------------- 12-11-2014_14-10-1 -------------------------- Selected model: E1205Y Selected port: COM4 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM308 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Backup\nvitem_E1205Y _12-11-2014_14-12-14.bin Sending SSBOOT... OK Sending PS... OK Sending CSC... OK Erasing FLASH... OK Flashing done (time - 00:02:34) Done with Samsung Tool v.18.3 Thank you |
11-14-2014, 10:24 | #2 (permalink) |
Freak Poster Join Date: Dec 2009 Location: pakistan
Member: 1192442 Status: Offline Sonork: 100.1638070 Thanks Meter: 15 | use E210 combo cable but only usb not rg45 without battery connect phone press (ok)Button while connecting phone to the Cable in-case phone goes dead then 2nd option z3x backup nv file Automatically Go to Dump select flash mode on dump press write C:\Program Files\Z3X\Samsung\SamsungTool\Backup\nvitem_E1205Y connect phone again without Battery press (ok) after write nv file ur phone will be alive and sim lock/phone lock will be removed........ |
The Following 2 Users Say Thank You to phantom_cellule For This Useful Post: |
11-14-2014, 10:38 | #3 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Rangpur,Bangladesh
Member: 1675107 Status: Offline Sonork: n/a Thanks Meter: 145 | bro try with select 1202i or flash it http://forum.gsmhosting.com/vbb/f453...ng-ok-1810073/ |
11-14-2014, 10:41 | #4 (permalink) |
Member: 1192442 Status: Offline Sonork: 100.1638070 Thanks Meter: 15 | use E210 combo cable but only usb not rg45 without battery connect phone press (ok)Button while connecting phone to the Cable in-case phone goes dead then 2nd option z3x backup nv file Automatically Go to Dump select flash mode on dump press write C:\Program Files\Z3X\Samsung\SamsungTool\Backup\nvitem_E1205Y connect phone again without Battery press (ok) after write nv file ur phone will be alive and sim lock/phone lock will be removed |
11-16-2014, 16:17 | #5 (permalink) |
Member: 1020935 Status: Offline Sonork: 100.1604039 Thanks Meter: 28 | Hi Thank you so much for reply Both of you i'll try and will post result Thanks once again |
The Following User Says Thank You to !!AS!! For This Useful Post: |
10-17-2016, 12:27 | #10 (permalink) | |
Junior Member Join Date: Jun 2007 Location: iran Age: 40
Member: 537020 Status: Offline Sonork: 100.1656317 Thanks Meter: 6 | Quote:
