09-21-2013, 14:20 | #16 (permalink) |
No Life Poster Join Date: Nov 2009 Location: india
Member: 1161713 Status: Offline Sonork: 100.1607798 Thanks Meter: 421 | Selected com port: COM12 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F816 Sending loader2... OK Please wait for patching firmware... Already patched SW Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 35348105247483 Phone slave IMEI: 35348205247483 Phone SW: E1207TDDLI5 Phone CSC: E1207TODDLI2 Phone BT ADDR: 0000-00-000000 Phone SN: RV1C97KCKZ Deactivated MSL - TRUE Unlock - ok Elapsed time: 58 second, sw ver: 3.5.0040 |
10-26-2013, 12:40 | #17 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1017041 Status: Offline Thanks Meter: 0 | Selected model: E1202 Selected com port: COM9 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F896 Sending loader2... OK Please wait for patching firmware... Patch block Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 35567705704371 Phone slave IMEI: 35567805704371 Phone SW: E1207TJPLL1 Phone CSC: E1207TOJPLL1 Phone BT ADDR: 0000-00-000000 Phone SN: RV1D564FTZ Deactivated MSL - TRUE [FREZEE]: 14868140 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00155556 [Phone Lock]: 84867195 Read info - ok Elapsed time: 59 second, sw ver: 3.5.0040 |
10-29-2013, 20:36 | #18 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2055801 Status: Offline Thanks Meter: 0 | USB connect Can Any 1 Help me in getting Driver or Pc suite for Samsung GT-E1207T In Specification there is an option for mp3 ringtones only and Also it supports Usb All I need is PC Suite or pc Connector for my samsung GT-E1207T , I searched much but could'nt found it .... I Want to Connect it to my pc via Usb and i need its pc suite or whatever soft through which i can load mp3 ringtones on it or any 1 tell how to send tunes in it coz its built in tunes are very awkward Waiting for reply Last edited by __Mirza__; 10-29-2013 at 20:41. |
02-20-2014, 14:37 | #20 (permalink) | |
Junior Member Join Date: Apr 2009 Age: 34
Member: 1019716 Status: Offline Thanks Meter: 3 | Quote:
02-24-2014, 15:16 | #21 (permalink) |
Freak Poster Join Date: Apr 2011 Location: punjab
Member: 1562820 Status: Offline Sonork: [email protected] Thanks Meter: 32 | Selected model: E1202 Selected com port: COM3 Selected speed port: 460800 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F816 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 51 second, sw ver: 3.5.0040 |
05-03-2014, 11:13 | #24 (permalink) |
No Life Poster Join Date: Nov 2011 Location: INDIA
Member: 1697041 Status: Offline Sonork: 1609691 Thanks Meter: 67 | Selected model: E1202 Selected com port: COM1 Selected speed port: 460800 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: F816 Sending loader2... OK Please wait for patching firmware... Already patched SW Please, connect phone and press power button 3 seconds Phone Detected Timeout Phone fail TAT MODE Deactivated MSL - FAIL Elapsed time: 73 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
10-30-2014, 05:48 | #26 (permalink) |
Insane Poster Join Date: Sep 2011 Location: tirunelveli Age: 40
Member: 1655874 Status: Offline Thanks Meter: 13 | samsung e1207y phone lock done with valcano... open valcano 2.4.3 select spd tab select 6530 boot now tick phone reset press run button and now press center button in the phone all ok |
11-29-2014, 07:36 | #27 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1271316 Status: Offline Sonork: 501101 Thanks Meter: 22 | hwk solve this problem open sams & select e1202 mobile inffo patch MSL unlock it Connect Cable to Switched Off Mobile (with battery) Software: E1207TDDMJ1 Hardware: MP 0.200 Warning, Wrong Product Selected [E1202] Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2013 October Rev: 1 CSC Vers: E1207TODDLJ2 INS Customer: India Use [Patch MSL] to bypass MSL S/N : RZ1DC0PRYM IMEI: 358662-05-968166-3 IME2: 358663-05-968166-1 Use [Patch MSL] to bypass MSL Use [Patch MSL] to bypass MSL Connect Cable to Switched Off Mobile (with battery) Preloader Ok F8, 921600 Baud Flsloader Ok FLASH Id: Fidelix, FM25M64A File CRC: 0x6212678D MCU Write Done, 262144 byte(s), Time: 00:13 MCU MSL Patched Ok, Time: 00:30 Connect Cable to Switched Off Mobile (with battery) MSL Deactivated MSL Deactivated SLOCK Reset, Ok Unlock Done |
01-23-2015, 17:11 | #28 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: india Age: 49
Member: 901335 Status: Offline Sonork: 100.1652281 Thanks Meter: 151 | E1207T unlock done bt z3x Quote:
02-10-2015, 17:09 | #29 (permalink) |
Junior Member Join Date: Dec 2010 Location: howrah Age: 33
Member: 1469228 Status: Offline Thanks Meter: 0 | Samsung e1207y lock by volcana Box 1000% Open 'volcano box' select 'Spd ' " 'built-in boot _13 6500/6530 ' " 'phone Reset ' unlock the ur samsung 1207y totaly 'built-in boot _13 6500/6530 ' read flash Detection initiated... Vcc: 13 14 Gnd: 1 2 4 6 Analyzing D+ and D-... D+ = 16, D- = 17 Detection D+/D- with 1.25 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 11 Setting... Find USB device:SCI USB2Serial (COM38), (VID_1782&PID_4D00) Pinouts setting complete! select 'phone Reset'''''''''''''''''''''''''' Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.2 CPU TYPE:[6530C000] FLASH ID: 00C8006000170000 Flash Type:[GD] 25LG64bWL Size:0x800000(8MB) >>Set to Factory successfully. |
