01-11-2013, 10:50 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 838176 Status: Offline Thanks Meter: 57 | samsung E1220 successful phone lock code Flash ID: 7A Sending loader2... OK Please wait for patching firmware... Patch block Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 35184105222572 Phone slave IMEI: 35184105222572 Phone SW: E1220TDDLA3 Phone CSC: E1220TODDLA3 Phone BT ADDR: 0000-00-000000 Phone SN: RZ1C30VCTL Deactivated MSL - TRUE [FREZEE]: 15625630 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 [Phone Lock]: 00014743 Read info - ok Elapsed time: 50 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
The Following User Says Thank You to manish_jain For This Useful Post: |
01-11-2013, 15:01 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Good Work Dear Thanks For Success Report. BR. Arsalan gsm2000. |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
04-16-2013, 16:58 | #3 (permalink) |
Freak Poster Join Date: Aug 2012 Location: jodhpur india Age: 41
Member: 1796401 Status: Offline Sonork: 100.1623409 Thanks Meter: 56 | PLZ HELP ME WITH E1220 UNLOCKING Selected model: E1125 Selected com port: COM124 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35184105073413 Phone SW: E1220TDDLA2 Phone BT ADDR: 0000-00-000000 Phone SN: RZ1C12LW8S Deactivated MSL - FAIL Use alternative method Unlock - ok Elapsed time: 14 second, sw ver: 3.5.0040 |
04-16-2013, 17:14 | #4 (permalink) |
Member: 1796401 Status: Offline Sonork: 100.1623409 Thanks Meter: 56 | USE SAMSUNG E1230 100% FLASH & UNLOCK E1220 FOR INFO........ Connect Cable to Switched Off Mobile (with battery) Software: E1220TDDLA2 Hardware: MP 0.100 Warning, Wrong Product Selected [E1230] Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2012 January Rev: 2 CSC Vers: E1220TODDLA2 INS Customer: India Use [Patch MSL] to bypass MSL S/N : RZ1C12LW8S IMEI: 351841-05-073413-8 Use [Patch MSL] to bypass MSL Use [Patch MSL] to bypass MSL FOR UNLOCK.... Connect Cable to Switched Off Mobile (with battery) Use [Patch MSL] to bypass MSL Use [Patch MSL] to bypass MSL Use [Patch MSL] to bypass MSL Unlock Done WBR. IMRANKHAN |
The Following User Says Thank You to imrankhan0143 For This Useful Post: |
08-22-2014, 11:32 | #5 (permalink) |
Freak Poster Join Date: May 2007 Location: jammu
Member: 506395 Status: Offline Thanks Meter: 48 | try with E1225T Selected model: E1225T Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 7A Sending loader2... OK Please wait for patching firmware... Already patched SW Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 35184105214640 Phone slave IMEI: 35184105214640 Phone SW: E1220TDDLA3 Phone CSC: E1220TODDLA3 Phone BT ADDR: 0000-00-000000 Phone SN: RZ1C22F7SY Deactivated MSL - TRUE [FREZEE]: 28546820 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 [Phone Lock]: 00012223 Read info - ok |
05-31-2016, 11:10 | #6 (permalink) |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | 1220t sim lock done. Code: Selected model: E1230 Selected com port: COM6 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 7A Sending loader2... OK Please wait for patching firmware... Patch block Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 35184105377873 Phone slave IMEI: 35184105377873 Phone SW: E1220TDDLA3 Phone CSC: E1220TODDLA3 Phone BT ADDR: 0000-00-000000 Phone SN: RZ1C427593 Deactivated MSL - TRUE Unlock - OK Elapsed time: 48 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
