01-20-2014, 09:25 | #16 (permalink) | |
Insane Poster Join Date: Apr 2005 Location: Tirana, Albania Age: 34
Member: 140959 Status: Offline Thanks Meter: 9 | Quote:
use these drivers to cinfigure the usb port. keep ok button pressed and insert usb cable to the phone wait until you see unknown device on device manager port. update drivers and select those one you just downloaded. unlock the phon. enjoy Br | |
The Following User Says Thank You to eugen For This Useful Post: |
01-23-2014, 19:11 | #17 (permalink) |
Freak Poster Join Date: Jun 2012 Location: valencia spain
Member: 1770619 Status: Offline Sonork: 100.1619675 Thanks Meter: 44 | Samsung e1270 unlock done z3x phone on conect usb cable install driver disconect phone phone must be off press unlock press home button conect usb cable Selected model: E1270 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM40 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Checking NV... OK IMEI Master: 3560270538XXXXX Phone HW: MP 0.700 Product code: Sending NV... OK Unlock done Done with Samsung Tool v.16.9 Done with Samsung Tool v.16.9 |
01-25-2014, 13:38 | #18 (permalink) |
Freak Poster Join Date: Nov 2009 Location: U.K (leeds)
Member: 1157490 Status: Offline Sonork: 100.1638346 Thanks Meter: 74 | Samsung E1270 2g unlocked. install drivers first (spd drivers for E1270) Connect turned off phone with usb cable and read codes or unlock. Selected model: E1270 Selected port: COM81 USB Serial Port Selected port speed: 921600 Waiting phone... detected COM794 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Checking NV... OK IMEI Master: 356027054794535 Phone HW: MP 0.700 Product code: Please wait, calculating codes... OK (time - 00:00:23) Freeze code: 35294791 NET lock: 26979163 Sub lock: 00000000 SP lock: 14285186 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.16.8 Done with Samsung Tool v.16.8 Regards, Champions |
06-25-2014, 09:55 | #22 (permalink) |
Junior Member Join Date: Feb 2008
Member: 699570 Status: Offline Thanks Meter: 6 | DEAR : FIRST OF ALL 1. TURN ON PHONE AND CONNECT WITH MICRO USB CABLE IT AUTOMATICALLY INSTALL THE DRIVERS SCIU25 INSTALL THE DRIVERS AND WAIT WHEN INSTALLTION DONE. 2. DISCONNECT THE PHONE FROM PC AND TURN OFF IT. 3. OPEN THE SHELL AND SELECT THE MODEL E1270 FROM MODEL LIST 4. NOW CLICK THE UNLOCK BUTTON AND CONNECT THE PHONE WHILE PRESS AND HOLD THE OK BUTTON KEEP PRESSING OK BUTTON SOFTWARE DETECT THE PHONE AND START UNLOCKING... Selected model: E1270 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Waiting phone... detected COM13 Sending FDL... OK Reconnecting phone... OK Reading NV... OK Checking NV... OK IMEI Master: 35XXXXXXXXXXXXX Phone HW: MP 0.700 Product code: Sending NV... OK Unlock done Done with Samsung Tool v.15.8 |
The Following User Says Thank You to usman_ghani For This Useful Post: |
07-16-2014, 13:26 | #24 (permalink) | |
Freak Poster Join Date: Aug 2006
Member: 329159 Status: Offline Thanks Meter: 3 | Quote:
100% working like that! the z3x tem forgot to tell that we have to press "ok" button... | |
07-29-2014, 15:02 | #25 (permalink) |
Junior Member Join Date: May 2014 Location: Ghana
Member: 2188204 Status: Offline Thanks Meter: 1 | Selected model: E1270 Selected port: COM117 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM102 Reading NV... error Done with Samsung Tool v.17.7 Selected model: E1270 Selected port: COM117 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM102 Reading NV... error Done with Samsung Tool v.17.7 Selected model: E1270 Selected port: COM117 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM102 Reading NV... error Done with Samsung Tool v.17.7 Selected model: E1270 Selected port: COM117 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... detected COM102 Reading NV... error Done with Samsung Tool v.17.7 |
11-02-2014, 07:45 | #26 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Sri Lanka
Member: 164422 Status: Offline Thanks Meter: 24 | how i did it just use the micro usb cable and connect the phone while switched off pressing the ok button.wait till it shows charging indicator and then it will install the drivers after unlock |
03-10-2015, 09:08 | #27 (permalink) |
Freak Poster Join Date: Aug 2014 Location: France Age: 34
Member: 2235775 Status: Offline Thanks Meter: 351 | flash file here... E1270_Down+PAC |
04-09-2015, 09:08 | #28 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 45
Member: 201107 Status: Offline Sonork: 100.1576954 Thanks Meter: 737 | i HAVE unlocked with just usb cable , simple unlock button. Freeze code: 07383085 NET lock: 75962860 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.18.5 b.r. kalpesh varia |
05-23-2015, 19:28 | #29 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2150938 Status: Offline Thanks Meter: 1 | Just Download the ''Samsung Spreadtrum Driver x64 x86'' Drivers from Octoplus Drivers ......and Follow as above. |
The Following User Says Thank You to sohailrana85 For This Useful Post: |
08-24-2016, 06:08 | #30 (permalink) |
Insane Poster Join Date: May 2011 Location: Inside Box
Member: 1580234 Status: Offline Thanks Meter: 47 | UNLOCK INSTRUCTIONS: Flash mode: COM Port does not matter, phone will be detect automatically. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. 2. Connect phone in flash mode (Press 'OK' button (Centre of navigation buttons module) and connect USB cable). Normal mode: 1. Connect powered on phone to USB, choose correct COM port in port settings. 1. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: GT-E1270 Selected port: COM51 SPRD U2S Diag Software version: 26.5 Reading phone info... OK IMEI Master: 3538*** Product code: Phone HW: MP 0.700 Phone S/N: RV1F8056KL Unlocking... OK Done with Samsung Tool PRO v.26.5 |
